N2O lots of questions? For the actuall users!!!
First of all I would like to say that im courious on the installation of a NO2 system on my F , but i have a ton of questions that I dont find awnsers on the forums...
Here it goes
What system are you guys using ? How much is safe of spraying , how much is over kill , reliability of the car after being spraid specially runing n/a again?
What are the one step colder plugs?
How you are spraying when our cars are by wire and no wot tps switch can be insatlled? Is some kind of maximizer really need it?
My car has now all the bolt ons , it laid down 400 whp on a dynojet, my goal is if I spray the highest ill go be 100 shot with colder plugs and some race fuel!!
Also , last but not least ! How and what fittings you used to tap into the F fuel lines?
Any advise will be appreciated
Here it goes
Here it goes
Here it goes
Dont need colder plugs
We use a WOT switch that reads the TPS. I use THIS
If you have headers, I wouldn't recommend spraying much. That said, your car should handle a 100 shot without a problem.
Fuel depends on the type of setup you want to use. You can utilize a race cell, or tap into the port injection system. Whoever does your installation should be knowledgeable enough to figure out the correct fittings to use
Thanks for jumping in, I know you used to spray 150 shot right???
Im only planning for the 100 shot the safest way, yes i have ppe
What where your numbers?
I was thinking NEX efi wet universal, w some sord of wot switch, heater , and purger , something simple what you think?
Here it goes
Here it goes
factory plugs are what i would run. but there is a NGK plug one range colder that runs within the ISF plugs spec.... will try and find the part number.
Car love juice but dont spray too early as you will find limp mode quickly....
With the inability to retard our timing while spraying i would recommend this. Safest possible way to spray in my opinion.
http://www.uprproducts.com/nitrous-e...rnal-pump.html
I8ABMR
03-12-08 10:27 AM
