Sway bar
Old 03-30-14, 12:21 PM
bacardi11
bacardi11's Avatar
Default Sway bar
hi guys
i'm from the 430sc. I understand the ISF rear sway bar is 17mm is this correct? the F Sport is 19mm correct?
this is a straight rear sway bar? what is end to end length of this sway bar?
any help is needed.
cleethree (04-11-18)
Old 03-30-14, 02:18 PM
flowrider
flowrider's Avatar
Received 1,924 Likes on 1,356 Posts
I use the F-Sport Sway Bar, and yes your understandings are correct. See these thread:
https://www.clublexus.com/forums/is-...my-2010-a.html
https://www.clublexus.com/forums/is-...-and-is-f.html
https://www.clublexus.com/forums/is-...patibilty.html
Lou
Old 03-30-14, 02:38 PM
jlam86
jlam86's Avatar
Went to the dealership to inquire about the f sport sway bars and they said they don't exist. The isf comes equipped with the beefiest bar available for the IS line up from lexus. ..
Old 03-30-14, 03:55 PM
bacardi11
bacardi11's Avatar
what is the end to end ( length ) of this bar?
the F-Sport IS250 AWD 17.5 Dia. will also fit? if the end to end length is the same length as my 430sc bar I will be installing bar in my 430sc car. my main thing is to know the complete length of the bar + the corners.
with a little more help from you guys I may make this work.
again complete length of this bar.
Old 03-30-14, 04:44 PM
flowrider
flowrider's Avatar
Your dealer is FOS
Lou
Old 03-30-14, 06:40 PM
fasttexasz
fasttexasz's Avatar
Originally Posted by lowrideraz
Your dealer is FOS
Lou
Really is a shame most dealers are like this, but it is a sad fact of life!!
Old 03-30-14, 09:00 PM
FraganciaF
FraganciaF's Avatar
I'm getting me the sikky sway bar :-) can't wait ...
Old 03-31-14, 05:26 AM
darbs242
darbs242's Avatar
Love my sikky bar!
Old 03-31-14, 05:34 AM
bacardi11
bacardi11's Avatar
Fragan
when are you getting the sikky? need some one to give me the complete bar size length,
Old 03-31-14, 07:09 AM
FraganciaF
FraganciaF's Avatar
Originally Posted by bacardi11
Fragan when are you getting the sikky? need some one to give me the complete bar size length,
don't know the length of it i just know that the sikky sway bar fits my car lol
Old 03-31-14, 10:26 AM
bacardi11
bacardi11's Avatar
dose any body know the length of this sway bar?
Old 03-31-14, 03:28 PM
dannyk8232
dannyk8232's Avatar
From motoiq dot com:
We opted for a Sikky rear anti sway bar. The Sikky bar is 2mm larger than stock at 19 vs the stock 17mm and is straighter with less bends which makes it more effective.
Old 03-31-14, 03:34 PM
flowrider
flowrider's Avatar
^^^^Doesn't answer the OPs question. I attempted to crawl under my F this morning. Not really enough room to do it easily. I'll try some other time.
The stock F sway bar has a middle kick-up section to allow the use of a full size spare that is used in some markets other than North America.
Both the Sikky and the F-Sport are straight (not for use in other than North America markets). The straight design along with the increase in diameter will make for a stiffer bar.
Lou
Old 04-01-14, 06:21 AM
melbitoast
melbitoast's Avatar
Lou
Lou, are there any major differences b/t the Sikky sway bar compared to the F-Sport sway bar? Specifically, does the Sikky sway bar outperform the F-Sport bar by so much that it justifies being 2x as expensive? Sikky is $300, F-Sport (thru Sewell) is $156.
Old 04-01-14, 06:47 AM
bacardi11
bacardi11's Avatar
as for as I know the Sikky is 19mm and F-Sport 19mm no difference. 19mm is 19mm
that why I need to know the length so i know it will fit the 430sc.
the guys in japan say the 19mm is to much for the street great for track.
Quick Reply: Sway bar
