Wheel fitment questions and opinions-please
Okay guys I need your help with some more wheel and tire questions.
I am sorry I could not find the info I needed on here first. I just don't have hours to read through wheel threads to find someone asking about the same setup I am planning on using.
MAYBE A STICKY?!?! LOL!!
I am looking at this setup:
20x9 front
20x10 rear
Front: 35mm
Rear: 40mm
center bore:60.1mm
bolt pattern:5x114.3
I need to know if this will fit under an ISF, with no modifications and what size tires you guys would recommend . But I guess most importantly, will the wheel specs listed work on an ISF!?
Again any help is much appreciated.
Also I need you guys opinion on these wheels. Im pretty sure I have narrowed it down to these two wheels. On Smoky Granite Mica colored ISF.
http://www.nicheroadwheels.com/milan-m135-w-9315.htm
or
http://www.nicheroadwheels.com/verona-m151--w-14454.htm
Again any feedback positive or negative will be greatly appreciated.
20x9 front
20x10 rear
Front: 35mm
Rear: 40mm
center bore:60.1mm
or
I am already lowered on Swift springs. Dont plan on going any lower. My main concerns were the offsets and center bore. Will those offsets look right and will I need hub centric rings for that center bore. But thanks so far.
This should work fine as I was looking at this setup myself going with the Rohana RC10 wheels (see below)...This picture is the 20x9 +38 and 20x10 +40 setup but the recommended tires from Rohana where 245/30/20 and 285/25/20...great look IMO!!!
![Name: Rohana.bmp
Size: 1.28 MB](https://www.clublexus.com/forums/attachments/is-f-2008-2014/321949d1396364362-wheel-fitment-questions-and-opinions-please-rohana.bmp)
Attachment 321949
Attachment 321949
Yes and for some reason Rohana also told me that if I ran the 275/30/20 on this setup that I may have rubbing issues...it must be a pretty tight fit...LOL
Attachment 321949
Attachment 321949
or
or
