Need help identifying +/- wires going to battery
Hi guys, I'm hoping someone can help me discern the + and - wires at the battery of the IS-F. I thought I had a good idea but now with everything back in the car my memory is hazy. I cant definitively confirm point A to B in TIS either. Any help would be greatly appreciated! Sorry if the descriptions/pics are confusing.
1. Black large gauge wire coming from engine, has + battery terminal post attached. Has smaller gauge long length black wire bolted atop terminal. Where does the long wire go to?
Long wire ontop of + terminal:
Long wire end not connected:
[IMG]http:
2. Black wire from bottom of passenger side fuse box terminal to + battery ? (wire is marked with a +) ?
[I
3. Black loomed wire coming from back side of engine goes to _____ ?
(its buried atm .. but I believe its the Violet colored wire in TIS diagram)
I'm good with these (I think
4. Black wire from engine head to passenger side top fuse box.
5. Black ground wire from Alternator to chasis ground.
6. Negative battery terminal wire grounds to chasis beneath Steering ecu/battery.
Pic of Grounds courtesy of TIS:
[IMG]htt
[IMG]http:
[I
[IMG]htt
look @ this post about changing out the spark plugs... there's a picture where the battery has to be removed... it's the last 2 pictures that you will be interested in... from the second to the last picture, it's possible the ground wire connected to a plate that's connected to a heat sink component but that wire has a wire loom over it...
I just did my spark plug change too but i've covered everything back up but see if you can trace the wires to your setup...
In this pic of the + battery terminal: Does the wire bolted to the top of the main + just go into the bottom of the fuse box? I believe it does but on mine I have the long wire unattached which I believe should not be on the v8 motor. lol
![](https://i625.photobucket.com/albums/tt336/trixxxter/Lexus%20IS-F/DSCN05561024x768.jpg)
well looking at the schematics from TIS there is a ground wire that goes to the fuse box, that ground wire should probably bolted to the bolt inside the fuse box that's pictured in your second picture... i am not @ home and don't really want to remove all the covers but if any1 can confirm if there is a ground wire in the fuse box, that may be where that wire that you are holding in the second picture should go...
Here is what I'm dealing with. Found an old pic and identified the + wires in question!
On the + battery main terminal mine is not hooked up to anything. The yellow outline in the pic traces the main + terminal wire. The red traces the bolted on + wire to the + terminal. I believe the red is wrong and should be removed so that the bottom fuse box wire bolts to the + terminal as said above by Lou. But the yellow has me concerned as to wth I need to connect it.![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Welllll did some digging on the v6 motor in my garage... The main + terminal originates from the Starter. Took a few pics. Motor has got to come out for me to remedy my mistake on the v8. ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Here it is missing on the F starter:
[IMG]http
And in place on the v6:
[IMG]http://i61.ti
[IMG]http
[IMG]http://i61.ti
feesreveng
05-27-18 04:42 PM
