60-0 Braking distance oem vs aftermarket pads / rotors?
Anyone have any feedback on the braking distance with oem and aftermarket pads / rotors?
also with repeated braking, any fading ?
Braking distance between pads are the same, the tires will determine the braking distance since tire to ground friction > pad to rotor friction.
If you need reviews on brake fade of the pads then you need to read the reviews on other websites/forums.. their reviews are applicable.
^^^^I have had them both. I never compared the braking distance, but, IMHO, the DS2500 outshines the stock pads in every respect.
While bedding the pads I build up a lot of heat, there was never a sign of fad, or hard pedal. In normal driving the feel is far superior to the Brembo Pad and somehow I feel more secure with these. I have nothing but Good Things to say about the Ferodo Pads. I luv 'em.
https://www.clublexus.com/forums/is-...rake-pads.html
Lou
Lou
colorfan
04-26-16 01:58 PM
