Camber Toe Caster Adjustments
Going to get an alignment done on my F tomorrow.
Wanted to confirm what adjustments are possible on the F.
I read in other threads that there are no front/rear caster & no rear camber adjustments.
Then are the following adjustments possible?
Front camber
Front toe
Rear toe
I am on tein coilovers with about 1.5" front & 1.1" rear drop.
I know it will not be possible to be within oem specs with my drop.
What numbers should I target if my goal is to minimize front inner tire wear without using additional aftermarket suspension parts.
I read that I should target 0.0 to +0.1 for front toe.
Thank you
Front camber
Front toe
Rear toe
Thank you
SprtDesign
09-09-13 04:06 AM
Sheehan1p
Suspension and Brakes
26
05-29-11 11:54 AM
