Replacing driver's side door handle
Old 06-10-14, 11:51 PM
sr20bet
sr20bet's Avatar
Default Replacing driver's side door handle
Other than removing the door panel to unplug the electrical connector to the door door handle, is the rest of the door handle replacement similar to the video below? or is it different for the 2g is models?
Any help greatly appreciated.
Old 06-11-14, 12:10 AM
LOLM3
LOLM3's Avatar
I had to remove my handles when I wrapped my car. You also need to remove the panel to remove another torx bolt that holds in the main handle as well. You can use a torx, however a hex works just fine too. It should be pretty straight forward otherwise.
These are the two screws you need to remove
Old 06-11-14, 12:19 AM
sr20bet
sr20bet's Avatar
Thank you for this info.
How long would you guesstimate the job to be? hours? mins?
Nice wrap on your isf.
Old 06-11-14, 05:55 AM
LOLM3
LOLM3's Avatar
It takes 10-15 minutes for me to do. It may take 30 since it's your first time. Thanks, good luck!
14ct200h
CT 200h Model (2011-2017)
10-26-18 10:14 AM
sallydrive
08-14-12 07:27 PM
Baybarea
05-17-07 04:20 PM
emmydotnet
12-02-05 07:55 PM
Quick Reply: Replacing driver's side door handle
