Brake question
Old 06-19-14, 07:23 PM
Compthis
Compthis's Avatar
Default Brake question
I've done my brakes now for the second time, both times using OEM parts. The first time I had them done, the brakes had high stopping power, that bite you get from slightly touching the brakes, I loved it. I just had them done again and don't have that bite. I need to apply more pressure to stop the car. I've flushed my brake lines as well using OEM fluid. With both brake changes, I didn't bed them in. I'm feeling inclined to head out and give it a shot but I didn't need to the first time so what gives?
Old 06-19-14, 07:46 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,064 Likes on 2,461 Posts
Are they the same make and model of pads? If they're the same, they should not need bedding. Are you confident they removed all grease, oil, and fingerprints from the rotors and pads when the install was done? It's pretty easy to make a mistake and get the magic copper goop in a place where it should not be.
If you changed to a different brand or model of pads, you'll need to bed them in before they'll work well. Sometimes you'll even need to take garnet paper to the rotors to scuff off the old pad material.
Old 06-19-14, 07:53 PM
Compthis
Compthis's Avatar
Both times I changed the brakes I used new OEM brembo pads and rotors. Do you think I can buy brake cleaner and give them a spray, will this do the trick?
Old 06-19-14, 07:54 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Maybe. I'd do the brake cleaner and bed them in to be certain.
OEM pads are not Brembo. They're Jurid. It's possible they've changed manufacturers over the years.
Old 06-19-14, 07:57 PM
Compthis
Compthis's Avatar
I could be wrong but the pads actually have brembo written on them
Old 06-19-14, 08:08 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
None of the ones I have seen say Brembo. They all say Jurid. Jurid is one of the largest OEM pad companies. 1 in 3 cars had Jurid pads from the factory.
EPC describes them this way:
04465-0W120 MARK JURID 655-GF
Interestingly enough, a Google image search shows a set of pads with Brembo stenciled on them in white paint. Unfortunately, Jurid 655 GF is stamped in the metal backing plate, so Brembo's paint job is clearly a rebranding effort.
Old 06-19-14, 08:36 PM
Compthis
Compthis's Avatar
This is exactly what I got. Doesnt matter front pads, rear pads all say brembo. All bought from sewels
And a link to a set for sale. http://www.lexusfforum.com/forums/at...0&d=1342116389
Old 06-19-14, 08:58 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Look right above the silk screening where JURID is stamped into the backing plate. Case closed.
Old 06-19-14, 09:42 PM
kzlflash
kzlflash's Avatar
Off topic, but I changed my front rotors and pads 5k miles ago. It's time to change my rear rotors and pads, but I'm wondering whether the bed in procedure would be the same as when I changed the front. I know most of the braking power comes from the front, so I'm not sure if I have to do the same amount of stops, or whether bedding in would be necessary. The rotor brand is Raybesto, with stop tech pads.
Old 06-20-14, 06:03 AM
digger08
digger08's Avatar
Rick usually scuffs all of the rotors with emery paper, when servicing the brakes, and is also very careful with the "goop".
Digger08
Old 06-20-14, 07:44 AM
Compthis
Compthis's Avatar
Thank you Judge!
Old 06-20-14, 08:51 AM
Reaper21
Reaper21's Avatar
What is this "goop" you speak of lobux?
scamsel
scamsel's Avatar
what is the purpose of this 'goop' you guys mention?
Old 06-20-14, 08:53 AM
scamsel
scamsel's Avatar
ha, posted at exact same time, wth
Old 06-20-14, 12:02 PM
digger08
digger08's Avatar
High temp brake copper anti seize grease/ Lubricant....you know the gold stuff you see oozing out of your pads and shims.
Keeps pads quiet and active
Digger08
Quick Reply: Brake question
