would RPF1 fit
I'm thinking about buying some 19x8.5 22+ offset 19x10 22+ offset
would they clear the brakes in front? and would I have any rubbing issues lower on swift springs?
thanks
thanks
I have a 18x9.5+45 offset that needed a 5mm spacer to clear the brakes. Our cars require a high offset wheel so im not sure if the 22 offset would work out
thanks for the advice guys right now I have stocks rims with 20mm spacers and I'm trying to get that same look but without the spacers with a set of rims light and strong. any suggestions?
I would have to say with 25mm you will probably need to roll fender or use a lot of camber. cause in my case with 20mm and lowered on swift the back tires will rub just a little when going try a bump when the car has a lot of cargo in the trunk and back seat and the front tires rub a little when I turn going in reverse. but again with 20mm you are pretty safe 25 might need that roll.
toffee123
09-25-14 09:49 PM
Muti007
08-14-14 06:50 PM
