The question is.. is this easily reversible? If you gutted the cats and wanted to reverse it in the future, would the entire header assembly be need to be replaced? This would ultimately require the subframe to be dropped, which would make it an expensive job. I'm also curious to hear how it sounds completely decatted. I would imagine it sounds insane! I just don't want the gas smell
I cant wait to see the end result....def want to give this mod a try......just waiting on info about how to deal with the O2 sensor or adding the stimulators or the spacers added to remove the sensor from the exhaust.......
Not to state the obvious, but since there seem to be a few folks planning to take a hammer to their cats just remember that those things cost about $1900 each from Lexus.
Theres a set on ebay for $280 shipped. I have a set as well that I couldn't even give away a few months ago...
Guys, Keep in mind when you remove all cats, The Gas smell is coming... The only way to avoid this is by going with aftermarket high flow cats (secondary).
