Cali: recommend a place to get dash cam & radar hard wired
Hey guys,
I recently ordered a dash cam Lukas 7900 with back up battery and already have the beltronics rx65 (may grab the v1). I know there are the other smaller dash cams out there but after reading tons of reviews and watching tons of YouTube vids this was highly recommended for hot climates like Bakersfield ca where it will be 100 plus for next three months without a single day of rain.
I wanna hard wire the dash cam into the fuse box as it comes with parking mode and g sensor as well. It comes with a hard wire kit and small external battery that it will draw power from when the vehicle is left parked (so it won't ruin my car battery). It comes with a power safety so it won't drain your car battery.
Looking for a shop or forum member to do the install (willing to pay a fellow member). I am not very hands on and just don't wanna mess with running wires through the pillars and near the airbag.
Any feedback is appreciated.
Thanks
Thanks
I have this exact same camera for 1 year now. Originally on another car, but recently installed it on the ISF. I also have that Lukas "battery pack."
Install difficulty isn't bad. I used passenger side fuse box with an "add - a - fuse" to the door lock fuse (always hot), I think it's the #2 fuse. Make sure you get low profile ATM "add - a - fuse" like this one:
http://www.ebay.com/itm/321329859370...84.m1497.l2649
Hiding the wire in the headliner is simple and routing it down the passenger side A-pillar isn't difficult either, you can just pull off the A pillar cover. I made sure that the wire goes AROUND and BEHIND the airbag in the A-pillar, but I think even if someone lazily installed the wire in front of the airbag, the wire will easily rip apart upon airbag detonation.
It takes longer to change the oil than it did to install the camera. Give it a shot...
I installed mine above the rear-view and tapped into the mirror's wires and I had no idea what I was doing. Was really straightforward and only took about a half hour, and I think installing what you're looking to install would be a pretty easy DIY (and pretty gratifying).
I wanted to use the add-a-fuse on a hot\always on circuit that did not interfere with brake lights or ECU, so used the door lock fuse instead which was in the passenger side.
Did not zip tie or velcro the battery pack, I tucked it in with all the cables into the very right side of the passenger footwell. The carpet is "stapled" to a hard white plastic separator, so I just shoved the battery behind there.
I will post pictures later, for I will not be using the battery pack...something about high heat and Li-On batteries doesn't sound too safe, although it has been fine for 1 year when installed in the other car. Also the battery pack is only good for ~300 charge/discharge cycles and I think mine has been used way beyond that. Parking for just 4+ hours, the battery pack is dead by then, so I will only be using the 12V cutoff switch (the Lukas LK-290 device) instead.
