These are the truth! - Unlock that grip
Old 08-08-14, 04:34 PM
  #31
ISFpat
ISFpat's Avatar
Originally Posted by I8ABMR
NOPE . Tires on Tirerack are 22 lbs front and 24 rear for PSS. Compared to 27 front and 28 rear for the Bridgestones. That save 10 lbs in front a 8 in back
Thats 18lbs buddy !! Unless you are getting the info elsewhere , the math is correct.
In case anyone wants to check the numbers
Bridgestone RE050A
http://www.tirerack.com/tires/tires....=yes&tab=Specs
Michelin PSS
I'm quoting stock for stock.. 225/40 and 255/35
I wouldn't quote a larger size tire because they will always be heaver than stock sized tires.
Old 08-08-14, 04:48 PM
  #32
Need4Speed
Former Sponsor
Need4Speed's Avatar
You can never go wrong with the Michelin PSS I also like the Toyo R888 haha.
Old 08-08-14, 05:35 PM
  #33
I8ABMR
I8ABMR's Avatar
It was quoted for stock size 225/40/19 and 255/35/19 . It is an 18 lb reduction You may have been looking at a different size What is your source. Im looking at Tire racks numbers. Are you looking at the manufacturer ? They should be the same
Old 08-08-14, 07:24 PM
  #34
dannyk8232
dannyk8232's Avatar
WOW! The Falkens on my car are 31lbs each front and back! Must get PSS asap!
Old 08-08-14, 09:11 PM
  #35
I8ABMR
I8ABMR's Avatar
DO IT !! You will not be disappointed !!! Even the price is competitive
Old 08-09-14, 07:57 AM
  #36
scamsel
scamsel's Avatar
such a bonus that the tires are relatively lighter than most.
it looks like they make the tire in 275/35/19 now, wonder if anyone has tried that size, curious how it looks at stock height.
Old 08-09-14, 01:25 PM
  #37
I8ABMR
I8ABMR's Avatar
it has ben tried. A member with a blue one did it. In fact when I called tire rack about the tires they said they never recommend the 275/30. The recommend the 275/35.......seemed weird to me .
heres a link . Post #24 has the pic
https://www.clublexus.com/forums/is-...up-size-2.html
Old 08-09-14, 01:57 PM
  #38
MK4Sup_isF
MK4Sup_isF's Avatar
Not on stock wheels but I'm on 245/40 and 275/35 PSS, loving the setup vs my 2 sets of heavy S04
Old 08-10-14, 04:54 AM
  #39
WillRockwe
WillRockwe's Avatar
I had a blowout on a long trip and had to buy a new Conti from the nearest Lexus dealer. That commits me to Contis for the next set.
Old 08-10-14, 11:30 AM
  #40
I8ABMR
I8ABMR's Avatar
You can always donate that Conti to the tire Gods when you need to change the other three.Plus you dont want 1 old and 3 new tires. I had 2 new RE050As in the front. They were mounted 6 months ago in February and I beat the hell out of them on the track and donated them to the trash last week when I got my PSS with probably 80% tread life .
Old 08-11-14, 06:52 AM
  #41
NYC ES3
NYC ES3's Avatar
rode them this weekend again. they are made of glue. without these IMO you may be selling your f short. it freaking needs these. just a different car with them on. just grip. IMO better than the stock brdgestones
Old 08-11-14, 06:54 AM
  #42
4TehNguyen
4TehNguyen's Avatar
there is a reason why PSS is stock on many supercars. M3/M4/RCF have PSS as factory tires also
Old 08-11-14, 10:19 AM
  #43
LionelHutz
LionelHutz's Avatar
I have my set of PSS broken in enough to give initial feedback. GREAT tire so far. I replaced my RE050As when the rears had about 4/32nd and the fronts had plenty of tread, so this is not a spent tire vs. new tire comparison. I also upsized to 245/35 and 275/30.
First impression was that this is a shockingly more compliant tire than the RE050A, even with the shorter sidewall that I switched to. The brittle/skittish ride quality that I always found a little disappointing in the IS-F is pretty much gone. The PSS is also quieter than the Bridgestones, though not dramatically so.
Grip is better, though I haven't driven the PSS very hard. The car drives more solidly and is more communicative about how much traction it has. Cornering has neutraled out a little with the wider front tires.
Overall, I'd say the improvement to the car is nearly as big as when I put on BC coilovers. Very happy.
Old 08-11-14, 11:15 AM
  #44
flowrider
flowrider's Avatar
Received 1,900 Likes on 1,340 Posts
The reviews of the PSS are all excellent And, if they came in the 245/35/19 - 285/30/19 combo, which they don't, they would be on my F. But the SO4 also have good reviews, not quite as good as the PSS, but they usually run a close second and they do come in the 245/285 combo. As I've posted in earlier threads, I'm happy with my choice. Handling is much improved over my previous Continental DW in the 245/285 combo and the stock PS2s in stock sizes.
Lou
Old 08-11-14, 01:04 PM
  #45
I8ABMR
I8ABMR's Avatar
Lou
Lou, did the manager or a tech at discount tire mention anything about not being able to warranty the 285 rears because the rim was too narrow. Thanks buddy
Quick Reply: These are the truth! - Unlock that grip
