DIY Lexus '08-12 ISF - LED Fog lights
I'm sure for those perfectionist you can trim/shave the tabs for a better fitment or just buy oem ones. Took me about 20-30 minutes to figure it out and install them when i got home after work.
I came across this set of LED fog lights online, also I see there are images that was used from this thread as well... Although it's only cosmetic, but I like the idea to have DRL LED fog lights and I'm pretty sure there are modification need to do to connect to the fog light DRL harness.
Here is the link:
http://store.ijdmtoy.com/Lexus-Toyot...s-p/70-763.htm
Here is the link:
soo....I just got a 2010 ISF and I am looking to do this...I went on sewell for other parts and noticed that this was on there...
http://is.sewellparts.com/accessorie...2010/6625.html
is this going to have the same light output as most you see?
Great write up, thanks again for sharing. Were you ever able to post these pictures you mentioned? Interested to see night shots of the color and cut off.
