OS Giken LSD or OEM Torsen LSD?
Torsen or OS-Giken clutch type LSD?
https://www.clublexus.com/forums/is-...-type-lsd.html
Another happy FIGS customer - OS Giken LSD
FIGS OS Giken LSD swap write up
https://www.clublexus.com/forums/is-...-write-up.html
First Look: IS-F LSD Swaps w/pics (been happening in Japan)
https://www.clublexus.com/forums/is-...-in-japan.html
REMOVAL OF OEM DIFF UNIT and OS GIKEN UNIT REPLACEMENT
https://www.clublexus.com/forums/is-...placement.html
This is a few seconds of searching...go search, advanced, select ISF forum and enter what you want to search for...good luck. There is plenty of info out there in various threads.
Here's a detailed thread I made a while back on the OS Giken Super Lock Traction Control Differential (TCD):
https://www.clublexus.com/forums/per...l-tcd-lsd.html
OS Giken LSDs require no more maintenance than a Torsen diff. Unlike other clutch-type diffs, there is no need for the OS Giken LSD to be rebuilt.
OS Giken recommends that you change the differential fluid every 30,000-50,000 miles (depending on use).
Tech Info Resource
There's no incentive to buy the OEM spool by itself. The whole diff is only $300 more, and you will spend that just getting the spool into the housing if you get the OS Giken or Toms.
