Low Tire Pressure light
Old 11-05-14, 11:40 AM
Rickna
Rickna's Avatar
Originally Posted by 2URGSE
Seeing this issue as well with my 2013 that's not driven daily. I usually add air to bring all 4 tires back to 36 psi and the problem goes away. (Stock wheels, stock Michelin PS2's)
Sort of annoying, but oh well.
Can you calibrate the low psi alarm via Techstream?
Old 11-05-14, 03:46 PM
Maskaveli
Maskaveli's Avatar
I have my a 2011 with same light BUT mine is due to the 20" Vossen wheels, I've tried reading the manual but can't figure out how to reset it either. Car drives fine of course, light is just an eye sore.
Old 11-05-14, 04:05 PM
ISFpat
ISFpat's Avatar
Why would you? Low PSI is not a good thing..
Old 11-05-14, 07:05 PM
I8ABMR
I8ABMR's Avatar
pretty typical stuff this time of the year. I can only imagine how much the temps have dropped back east. LOL Its still in the 80s and high 70s here
Old 11-05-14, 07:54 PM
Rickna
Rickna's Avatar
I didn't say it was. Perhaps the low psi alarm is not configured correctly.
Old 11-05-14, 10:28 PM
ISFpat
ISFpat's Avatar
Wouldn't it be easier to check the PSI with a 5 dollar tire pressure meter rather than to "configure" the tire pressure system?
Just saying, I doubt the system is the culprit here.
Old 11-06-14, 05:36 AM
Rickna
Rickna's Avatar
Yes it would. I guess I got ahead of myself.
Old 11-06-14, 07:37 AM
Sean
Sean's Avatar
Mine started acting up again as soon some cooler weather hit. This time the light stayed on even with consistent 36-37 PSI on all wheels. Tire pressure wasn't even low to begin with. Techstream showed all sensors broadcasting, so I'm not sure what the deal was. I ended up just putting new sensors in new wheels synced as set 2.
Old 11-07-14, 02:42 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,969 Likes on 2,403 Posts
Did you reset them using the satellite switch after setting the pressure?
Old 11-08-14, 10:20 AM
Sean
Sean's Avatar
I cycled through the menu using the switch and selected "Initial pressure" when it came up. I also confirmed it was on TPMS set one. Is there another step I needed to take?
Old 11-08-14, 10:39 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Selected, pressed and held until showed Pressure Initial? That's the procedure for setting initial pressure. Page 298 in the 2008 Owner's Manual shows the procedure in detail.
There are batteries in the sensors and they do eventually die, but we haven't seen that yet AFAIK. They are expected to last 7 to 10 years, with 5 being worst case minimum.
The sensors themselves also have an absolute minimum (as I recall it is 27.5 psi) which will cause a low pressure light regardless of initialization pressure.
Old 11-08-14, 11:06 AM
Sean
Sean's Avatar
Thanks for the info. I didn't put too much effort into figuring this out since I knew I was going to be using a second set of sensors anyways. Failing to actually hold in the button was likely the problem. I'll probably use the stock wheels again someday so its good to know the sensors should still be ok.
Shrink
ES - 5th Gen (2007-2012)
12-02-23 09:31 PM
jrs21c
11-27-19 07:39 AM
Shrink
10-15-18 02:25 PM
Xwakeboard
11-21-07 03:32 PM
sidgriggs
09-21-06 08:17 AM
Quick Reply: Low Tire Pressure light
