Borla catback dyno numbers. Gained 28WHP and 24WTQ!
Old 01-24-16, 08:04 AM
  #91
Flogrown
Flogrown's Avatar
Just need headers and tune from RR and I'll be right where I want. Then off to my Turbo II build..
Old 01-24-16, 09:15 AM
  #92
Rickna
Rickna's Avatar
Originally Posted by Flogrown
I just got my car dynoed last night I have the Borla cat back and JoeZ intake I got 398rwhp!!!
Great numbers! Are you gonna tune?
Old 01-24-16, 01:19 PM
  #93
Flogrown
Flogrown's Avatar
Yes I am but, I want to wait for the first run to go out and see if anybody has issues.
Old 01-31-16, 02:43 PM
  #94
MileHIFcar
MileHIFcar's Avatar
Guys, I just installed the Borla exhaust yesterday, and I am very pleased with the sound and pick-up of the car!!
Can somebody chime in with the exhaust and answer a couple questions for me:
1. My driver side pipe the one that connects to the muffler section didn't have an exhaust hanger? I had one on the passenger side but not the drivers side??
2. So consequently the drivers side hangs down more than the passenger side because it's supported by the exhaust hangar on that side. Is that normal with the Borla?
3. When you look at the exhaust from the rear the drivers side exhaust tips look angled up like there is pressure from nothing supporting that back end?
I hope I didn't screw anything up on the install (Newbie) but would like some feed back if possible?
I'll upload some pics here in a sec
Old 01-31-16, 03:28 PM
  #95
MileHIFcar
MileHIFcar's Avatar
You can see the exhaust hanging down compared to the passenger side
See the angle of the exhaust
Old 01-31-16, 03:29 PM
  #96
MileHIFcar
MileHIFcar's Avatar
Let me know what I screwed up on??
Old 01-31-16, 03:44 PM
  #97
Rickna
Rickna's Avatar
IIRC, I had the same issue when my buddies did the install. They managed to "twist 'the left pipe up a bit, then held it in place with a jack and clamped it up.
Old 01-31-16, 04:40 PM
  #98
MileHIFcar
MileHIFcar's Avatar
Ok, I'm going to have to put the car on a lift again and see if I can tweak it a bit.
I'm taking that yours doesn't hang low like mine??
Also to clarify there is no hangar on the drivers side pipe towards the back on the Borla right?
Old 01-31-16, 05:24 PM
  #99
jat0223
jat0223's Avatar
Correct, there's no hanger on that side. You have to release the clamps push it up, make sure it lines up with the diffusers and then tighten it up.
Old 01-31-16, 06:17 PM
  #100
k20trick
k20trick's Avatar
yep mine was like that too on the driver side you just have to maneuver it around for best fitment, side no mount either while the passenger side had one.
Old 01-31-16, 07:38 PM
  #101
Rickna
Rickna's Avatar
Yep, no hanger on the diver side. when you're done tweaking the pipes it will rise up some.
Old 01-31-16, 08:02 PM
  #102
MileHIFcar
MileHIFcar's Avatar
^^^^Thx guys! I thought for a second I did something wrong. I have to bend back the heat shielding by the resonator because it's rattling a little bit, so at the same time I'll readjust/loosen the clamp and tweak the pipe and muffler a little bit.
Old 01-31-16, 08:52 PM
  #103
minator
minator's Avatar
same issue with mine when I first installed, I just loosened up the clamps and pushed the pipes around until it was level.
Old 01-31-16, 09:06 PM
  #104
MileHIFcar
MileHIFcar's Avatar
Sounds like a common issue with the Borla, glad mine wasn't defective or something! I'll readjust the pipes until they are level.
Thx
Old 02-01-16, 07:44 AM
  #105
jis3k
jis3k's Avatar
I recently Picked up an 08 IS-F two weeks ago. In saying that, I ordered the CarTreats 3" midpipe and found a good deal on some used rear Borla Mufflers that someone was parting with from the kit. Ill be putting everything on the car hopefully next week when I get some time and will give some feedback to add to the thread. Ill most likely have the rear section (axle back portion Fabbed) or I may leave it as it.. not sure yet.
Quick Reply: Borla catback dyno numbers. Gained 28WHP and 24WTQ!
