Oil change intervals
Old 10-22-14, 06:56 AM
calteg
calteg's Avatar
Default Oil change intervals
Does the IS-F have an OEM oil particulate sensor, or does it prompt you to do an oil change solely off of mileage?
Old 10-22-14, 08:15 AM
4TehNguyen
4TehNguyen's Avatar
does not have oil life %, its mileage based
Old 10-22-14, 09:32 AM
streetx
streetx's Avatar
mileage based
Old 10-22-14, 07:33 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,975 Likes on 2,405 Posts
Which manufacturer has a particulate sensor? I've never heard of a particulate sensor in an oil system.
OK, so I poked at it. What good is an iron sensor in determining TBN which is probably the most important attribute your oil has? Bearings are not iron, so what is this sensor doing other than telling you your rings are getting worn (duh)?
xenonrider
01-01-10 03:29 PM
roy1928
Performance & Maintenance
07-21-08 04:48 PM
ckh1272
05-31-08 09:53 AM
Quick Reply: Oil change intervals
