Cooling fan recall
#151
#157
Tech Info Resource
Add me to the list of new radiator recipients. The dealer didn't say a word, I opened the hood and saw the new coolant bottle and radiator when I was inspecting the wiring harness protector from the other recall.
Now I don't have to replace the coolant for another 60k!
#158
Received 1,064 Likes
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
So you did the ELF & Cooling fan bolts .. + bonus harness protector & New designed radiator
~ Joe Z
#160
Tech Info Resource
FYI - if your dealer has to replace the radiator, they will need to reset the ATF level in the transmission. The dealer who did mine did not do this and now I have all the old issues I had with low fluid - flare, holding in gear after hard turns, etc...
I do not understand why it is such a challenge to get quality work.
#161
I would say just pump in 4-5 ounces and call it a day
~ Joe Z
#163
What are the odds. My bracket assembly snapped before I had the work done. I was closing the garage door and before the door shut I heard a loud crack. I thought I was hearing things . Then the next morning when I got to work the car was shaking like crazy with AC on. Dealer covered it all but now I know why they are doing the recall. lol
#164
I wonder how many were affected. I was told that my VIN required the cooling fan and Fuel recalls. I got mine back today and was told only the ELF recall was done. Mine were tight and the part number wasn't one of the affected ones.
#165
Good thing it happened in the cooler months.!!
I was probably one of the first to see the failure happen.. I unplugged the secondary fan unit, until I had the time to fix it..
One of the reasons are those cheap *** oem bolts that go on dry with no Loctite at the factory..
The same new bolts are now installed with Loctite..
Mine new solution, as shown above, is a permanent fix..
~ Joe Z
