OBD2 Bluetooth with torque Pro App
#31
I'm using an amazon purchased adapter, and lose my tachometer on the dash when the app connects? Is this normal? I've never used something like this before.
EDIT: I'm going to try a different protocol in the settings based on that thread in the prius forums and see what happens.
#33
very strange joker i've never had that happen using my cheap obd2 dongle and torque pro.
this is the one i'm using:
https://www.amazon.com/Foseal-Scanne...s=obd2+adapter
Only reason I bought it is because i though i read on here that some people use it. I will try again later today with a different setting in the app and see if it works correctly. Besides the tach on the dash not working, everything else worked fine on the app.
#34
I love using the adapter and app.. It not only helps diagnose your vehicle but iv checked probably 12 people's cars informing them what was going on.. They all thought I was a genius.. If I could only turn off my damn tpms light...
#35
This is the one i have. https://www.amazon.com/Scanner-Amtak...s=obd2+adapter
#36
Update: I received a refund for my obd bluetooth adapter and bought a different one, better quality. Now i can datalog, and view sensors without any issue with my tachometer not working. Is there any specific setting that you guys use to get the app to update fastest? i tried some runs but the time readings may be off a bit.
here is the adapter I purchased: https://www.amazon.com/BAFX-Products...etooth+adapter
#37
I have been using this one for a few years now. I used it with my '08 ISF, 02 Mustang GT, '10 Mazda3, 04 Volvo XC70 and a couple other cars and never had any issues with it. I am however questioning the accuracy of the 0-60mph time. Someone was saying that it calculates your 0-60 based on your GPS coordinates, and if it is the case, any delay would cause a second or so difference.
#38
#40
Hi, can anyone recommend the best OBD2 Bluetooth Auto Diagnostic Scanner for an iPhone to use with the torque Pro App? I see many for non IPhones and want to make sure it compatible. If you could include am ebay or amazon link that would be great, Thanks!
#41
#42
OBD2 for 2001Ls430
Will the OBD2 work on a 2001 ls430 (3uz fe) 4.3lt v8? And if it works where do I insert it? I assume it goes into the ECU computer box?
califlexus
08-13-22 04:44 PM
