recommended engine oil for tropical countries
Old 12-26-14, 12:55 AM
Ltaboso
Ltaboso's Avatar
Default recommended engine oil for tropical countries
Hi all, i live in the Philippines and it never gets cold here, just keeps getting hotter, i know the 2UR-GSE uses 5W-30, what other options do we have for tropical coutries?
my engine oil temps never really get hot,the most i saw was 4 bars (from the instrument cluster) from hard driving along the freeway....since i found out we dont have an oil to air oil cooler,i just got a little worried and want to make sure my oil temps wont get super hot...
Thanks
Old 12-26-14, 01:44 AM
nipponbird
nipponbird's Avatar
There's not much reason to go away from 5W-30. You ought to have a viscosity chart in the owners manual, which you can compare to the minimum/maximum temperatures that you will encounter and you will be surprised what a wide spectrum is covered by 5W-30.
Old 12-26-14, 05:36 AM
Ltaboso
Ltaboso's Avatar
Ok thanks for the reply,ill go with the 5W30
Old 12-26-14, 07:54 AM
dwin888
dwin888's Avatar
I use Motul 300V 5W40
Old 12-26-14, 07:57 AM
flowrider
flowrider's Avatar
Received 1,906 Likes on 1,343 Posts
I live in Arizona, and use Pennzoil Platinum or Platinum Plus - Weight 10W/30. It never gets really cold here, and I've found it has worked out well for me.
https://www.clublexus.com/forums/is-...0w40-okay.html
Lou
Old 12-27-14, 04:33 PM
LexyISF
LexyISF's Avatar
5W30 Mobil 1 NVF 100% synthetic here.
Imagine Philippines weather and add 5*c, and that's what it's like where I am at the top of Australia. Hot, humid, and we're at the start of our monsoon rain season right now........
For your 30*c and below, I wouldn't bother using anything else other than 5W30.
Old 12-27-14, 09:54 PM
EpikOEM
EpikOEM's Avatar
5w30 Mobil one synthetic is what I use in Texas. It doesn't get as hot or humid as the Phillippines, but we don't get mild summers here either. It can get pretty hot and humid in Houston in the summer.
Old 12-29-14, 11:33 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,978 Likes on 2,406 Posts
This oil will make the engine run hotter and lose power compared to 5w-30. The engine was designed to work with 5w-30, why would you think heavier oil is necessary?
Old 12-29-14, 02:51 PM
LexyISF
LexyISF's Avatar
Especially with 10qt oil capacity!
tea
08-18-15 10:22 PM
Br7oom
05-21-15 06:20 AM
shiny250
11-30-13 06:55 PM
shikbas
02-07-10 12:20 PM
Mr Johnson
Maintenance
04-06-07 02:58 PM
Quick Reply: recommended engine oil for tropical countries
