Need Help About Wiring amp/sub
Hey guys I need some help about what I would need to wire my jl 500/1, w6 and capacitor I took it out my gs since my friend crashed it and gonna put it in my isf and let best buy do the install just need to buy everything I need. To get it to them and installed. Don't know that much about systems lol .Already got box and amp been mounted on custom board with box . I disconnected the power wires ground and capacitor just need to know wire sizes or specs whatever u call it and I'm also keeping factory radio . Thanks in advance
You can tap the harness at the amp (which is what rickna posted above) or run wire from your woofers for audio signals but it will have to converted via a LC2i, Cleansweep, bit10, etc. it's pretty much a straight forward/basic set up.
I wouldn't let bestbuy touch my car but that's just me.
I'm doing same thing right now, is there (1) or (2) pairs of wires going to sub ( ML) and plan on running the LC2i, had the Scosche SLC4 loc and the bass don't seem right with it.
In this case I got a aftermarket sub which is a jl w6 don't know how it would work lc2i is a 2 channel device that holds 400 watts is that compatible with my aftermarket amp which is a jl 500/1 amp and the subs ? Sorry if this is a stupid question or not don't know much about this system **** just don't want installer to rip me off an mess things up
One of the issues was the bass drop off at high volume. I read a post saying the solution was to put a 12 ohm 100 w resistor across the + & - inputs. on the lc2i.
Attachment 352260
Attachment 352260
You will be fine with the lc2i with your setup it's just a matter of bridging the channels. I have been running a Zed Minotaur and a Morel Ultimo for almost 2 years now with zero issues.
if the installer can't figure this setup out, RUN! The lc2i is the easiest line converter to hook up.
RobzKar
05-02-16 12:02 PM
