Top Fender Liner
Old 01-18-15, 11:23 AM
jadeboy
jadeboy's Avatar
Default Top Fender Liner
After installing BC Racing Coilover + Swift Spring which is lower than stock.. I've lowered the front another 1/2 inch.. Now going over moderate bump the tires are hitting the top of fender liner. I have tried to use heat gun and pushed the fender a little more up without success. Anyone have a solution.. If it involves removing the top fender liner.. Does anyone have a DIY?
Old 01-18-15, 11:37 AM
darbs242
darbs242's Avatar
stiffen your shocks
Old 01-18-15, 12:37 PM
Lexgendboi
Lexgendboi's Avatar
I had the same prob after dropping the car with KWV3. But only due to high way dip or occasional local street pot holes. I stiffened up the shocks and prob solved but the draw back is a bumpy ride
Old 01-18-15, 02:43 PM
jadeboy
jadeboy's Avatar
Right now.. the suspension is setup to the perfect comfortable level I want.. I prefer to not change the setting.
Old 01-19-15, 02:21 PM
Gearbangin
Gearbangin's Avatar
Whats your total drop front and back now?
Old 01-19-15, 09:15 PM
jadeboy
jadeboy's Avatar
1/2 inch lowered in front. Rear is stock BC R.
Old 01-19-15, 09:18 PM
1sWt2GS
1sWt2GS's Avatar
Theres bolts around the fender linder IIRC to remove it. Otherwise you can take a very sharp razor and cut out the part thats rubbing
Old 01-19-15, 09:45 PM
Lexgendboi
Lexgendboi's Avatar
Im not sure of removing the liner would help. As i mentioned above, my tire hit the very top of the liner due to highway dip, hence the plastic melt off where it hit, revealed a metal structure behind it. So im thinking even if you remove the liner, you would still hit this metal structure.
Old 01-19-15, 10:43 PM
1sWt2GS
1sWt2GS's Avatar
Not much you can do at that point unless you wanna heat up and get a rubber mallet that metal part
Old 01-20-15, 06:17 AM
Enough
Enough's Avatar
You need to increase the height of you bump stop on the shock shaft with a spacer to stiffen and limit the final travel of your wheel if you want to ride that low.
Old 01-22-15, 06:05 PM
jadeboy
jadeboy's Avatar
This sound good.. Never done this.. I hope this is not too difficult. Anyone done this on BC Racing coilover?
dfwjohnd
North Texas Lexus Club
07-13-14 01:55 PM
zinzan
SC- 1st Gen (1992-2000)
05-23-12 08:14 AM
Hoac
Suspension and Brakes
03-22-12 12:42 PM
isthrizzy
18
09-25-11 09:52 PM
soaringsc3
02-13-09 01:24 PM
Quick Reply: Top Fender Liner
