JoeZ installed, have a question (pics)
Old 01-19-15 | 02:41 PM
Defratos's Avatar
Defratos
Question JoeZ installed, have a question (pics)
So I finally installed my JoeZ exhaust yesterday, everything seems good but noticed that behind the passenger side muffler its touching a part of the car (dunno what it is)
Any ideas if this is normal or do I have to adjust something? The second pic shows the driver side muffler and it isn't touching this part. Any help would be appreciated:
Joe I tried sending u a message but your inbox is full
Old 01-19-15 | 03:12 PM
Justind27's Avatar
Justind27
That's one of the subframe mounting points
Old 01-19-15 | 03:17 PM
Defratos's Avatar
Defratos
Thanks for the info, for those that have the same exhaust is yours touching on the passenger side like mine?
Old 01-19-15 | 03:20 PM
USB_F's Avatar
USB_F
Loosen the bolts for that muffler, pull down and retighten
Old 01-19-15 | 03:22 PM
Justind27's Avatar
Justind27
^ I second this guys input
Old 01-19-15 | 03:27 PM
Defratos's Avatar
Defratos
Loosen what bolts? The bolts that connect to the front (mid section) of the exhaust? Or the muffler rubber hangers?
Old 01-19-15 | 03:34 PM
USB_F's Avatar
USB_F
Not the muffler hangers, leave those in. Loosen the bolts of the passenger muffler that connect to the mid pipe, pull down (may have to hold it down) while you tighten
Old 01-19-15 | 03:37 PM
Defratos's Avatar
Defratos
Ah ok, I'll try that and see if it helps.
I'll also see if maybe the mid pipe hangers are adjustable in anyway to help move it slightly down.
Thanks for the advice.
Old 01-19-15 | 03:39 PM
USB_F's Avatar
USB_F
There's not much give in the mid pipe hangers...
Unless you bought some different rubber hangers
Old 01-19-15 | 03:45 PM
Defratos's Avatar
Defratos
No I've used the OEM hangers and I know what u mean, the exhaust is pretty solid right now.
I'll see if there's enough movement for me to re-adjust the angel of where the muffler connects to the mid pipe.
Old 01-19-15 | 04:03 PM
lifethinkr's Avatar
lifethinkr
those hangers should bend just fine. take some kind of a cheater pipe on the end of the hanger and bend the tip down. all you need is a half inch. or you can try removing the hanger bracket, put it in a vise and heat the tip up with a propane torch. the hanger will bend I guarantee you that.
Old 01-19-15 | 05:59 PM
Joe Z's Avatar
Joe Z
Lightbulb
^^ There is no reason to bend anything for proper fitment..
As stated.. Losen the 2 bolts on the right axle section connection only..
Pull down exactly where its touching on the section and retighten = problem solved.
Having the car back in the air and doing it with two people would be best..!!
As discussed in PM, when running aftermarket headers things will fit a bit differently, but nothing a few adjustments can't solve..
Enjoy the new setup..!
Also, what kind of Black Finish did you give the mufflers & piping..!!??
Joe Z
Old 01-20-15 | 11:31 PM
Defratos's Avatar
Defratos
Thanks for the feedback Joe, I will be doing this in a few days.
The muffler pipes are just resting on the metal part so it's not damaging anything and absolutely no noise.
I used some high temp spray paint on the mufflers and muffler pipes to try and make the exhaust look more stealthy lol, but its obvious I've installed something
Once again awesome product
Old 01-21-15 | 01:35 AM
Meraki Autoworks's Avatar
Meraki Autoworks
Your #1 Lexus Vendor
like everyone stated, I had the same problem, loosen some bolts, pull it down, and tighten it again. wallah.
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 01-24-15 | 10:53 AM
Defratos's Avatar
Defratos
For reference sake, did as suggested above and everything fits perfect now
Frank2029
07-04-15 07:39 PM
2genIS
Performance
04-06-12 08:13 PM
zojirushi
IS F (2008-2014)
04-08-11 08:07 AM
jv250
Performance
03-31-11 06:04 PM
