2011 headlight upgrade...i searched...just want to make sure
i have a 08,and thinking about the headlight upgrade, do i need to purchase the flasher relay as well? Or the DRL will work without it?
Just need to make sure because il be ordering it from the u.s. (im in the philippines)
TIA
TIA
Relay p/n : 81980-06020
this mod does not require any re-wiring or splicing right?
As I understand it, the LEDs won't work as driving lights without repining some of wires in the headlight wire harness. Even with that, you still will not get the 50% bright LEDs when the headlights turn on without running a separate relay. Also, your AFS-off light will be constantly on in your dash since these headlights no longer contain that feature.
I'm sure there is more to this that I am missing as well.
From my understanding, If you don't have the newer flasher module, your blinker will blink very quickly. Repinning is needed for the LED strip, but no splicing, however there is also some rewiring involved and adding an additional relay if you want them to operate at 50% bightness with the headlights on.
I'll be going through this soon enough and have already done some of the prep work (AFS light, disable DRL).
There are threads detailing all of these items but I don't have them bookmarked on this computer and am too lazy to search
Yes there is a lot more to this.
Thats why there is already a 200 page thread on the topic. Plus multiple postings on specific IS F related questions in here.
Do your research first, before ordering the lights.
To name a few things:
OEM from Sewell plug and play lights versus OEM lights
Repinning the power connectors
LED operation
AFS dash light
Relay Falsher change
Bumper fitments - modifying to fit 2008
etc....
Digger08
LED operation
AFS dash light
etc....
Digger08
I hope you guys know that if you plan on doing this mod that you will not be able to use the LED strip as a "DRL" without turning your parking lights on..... or having your headlights on full on. I did the MY2012 upgrade and I thought the LED strip would work as a DRL like the 2011-2014 is' would but it doesn't without turning your parking lights on. IMO it looks goofy because your rear taillights are on when you have the parking lights on. The only way to have it as official "DRL's" is to have it hardwired to your ignition. which you can also find in the "search"
LED operation
AFS dash light
etc....
Digger08
LED operation
AFS dash light
etc....
Digger08
Just curious to know, do you current have the AFS dash light too? I followed your build thread on my.is and forgot if you commented on it.
Westsai
10-25-15 09:14 PM
Vibes63
04-02-13 08:04 PM
