has anyone tried removing plastic engine cover for better cooling?
i was thinking to remove the plastic cover for better cooling...just wondering if anyone tried it already with results...
i use to have an altezza rs200,and 1 of the problems with the 3sge is the coils heating up resulting to failure (misfire) they concluded that the engine cover is keeping the coils too hot,so it will fail earlier than expected (specially in tropical countries),so what they usually do (including the TRD altezza) is cut the cover maintaining the cover for the timing belt,but from there on,they will remove it....
i hardly show my engine bay (and most people just look at the exterior nowadays) so if it would help a bit in terms of cooling,i wouldnt mind driving without it....
TIA
TIA
I removed the two plastic side pieces. Left the front plastic because it helps guiding the air to the intake. Kept my engine cover since I have vents on my carbon hood. This way any water in the vents will drained directly away from the electronic above the motor. I can really see the heat waves through the vents when stop at the light. So the vented hood works great. The grill is pretty damn hot to the touch too
He has the Seibon TSII vented hood, with the majority painted body colour. Just the vents are carbon.
https://www.clublexus.com/forums/is-...for-isf-6.html
See post 81 on the link above.
Tech Info Resource
Removing the engine cover won't help cooling under normal conditions. Under normal conditions, your oil temp never goes over 3 bars. If you are at the track, it will help.
Tech Info Resource
The engine cover traps heat and suppresses noise. Removing it and opening the hood when not on track makes a big difference in time to cool.
Tech Info Resource
Lots of things don't register on the dash. Only the bare minimum of information is supplied to the driver to avoid warranty issues.
