Tranny fluid change....
#61
Tech Info Resource
Look at post #52 in this thread. There are two pins you short in the DLC and then just move the shifter as described and you're in the temperature sensing mode. No tools necessary. Just be sure to start with the car cold - overnight cold - because there's no way it will cool from normal operating temperature in any reasonable time other than overnight.
Positron (04-01-20)
#62
I'm not sure if the F has an external fluid cooler but if it does, that is where to change it, provided I can refill it. You can pump put the trans from the cooler return, wait for it to sputter. Measure how much came out, refill that exact amount and repeat. Soon the fluid coming out is new and you are done. Very little shock to the system and gets the converter, valve body, everything. Again though, not sure this will work on the F.
I've attached the procedure for fluid replacement from AllDataDIY
Keep in mind that some Toyota transmissions have a thermostat that you will need to bypass in order to allow the new fluid to circulate in the transmission. Both my LX570 and GX460 have this, although that's not the same transmission. Not sure if this 8 speed has it also. Something you'd want to investigate. Nonetheless, do not run the transmission pan dry. Better to overfill slightly and when you're done changing out all the fluid, adjust the level using the factory procedure before driving the car.
#64
That “ special Toyota pump” …
inovashn (02-24-23)
DDGS350
05-06-09 01:06 PM
