LED Front Turn Signals (VIDEO)
Finally installed my LED front turn signal bulbs after waiting three weeks for them to come in
. The first set of LEDs I ordered were too long so I had to order some shorter ones that would fit in the headlights. The LEDs I installed are much brighter than the OEM halogen bulbs and also look a lot better when they are on. Not bad for $30. While I had the headlights off I also took out the goofy little halogen bulb that turns on in the high beam bowl when you have the headlights on. Also while I had the front bumper off I went ahead and ordered the OEM LED fog lights and installed them as well. Now the headlights and fog lights match
![](http://i594.photobucket.com/albums/tt30/1992shadow/IMG_1766_zpsouqzjznq.jpg)
These are the LEDs I got for the front signals. You need 2 sets of them since the ISF's have two turn signal bulbs in each headlight.
http://www.ebay.com/itm/331304297740?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The LED flasher is located up under the dash behind the steering wheel. If you lay on your back and look up by the pedals you will see a little blue box up under the dash. If you can't see it just turn your blinker on and find where the "blinker" noise is coming from. You need to unplug the OEM flasher and replace it with this one.
http://www.diodedynamics.com/store/2...signal-flasher
where does the LED relay go?
__________________
![](https://www.clublexus.com/forums/signaturepics/sigpic167102_16.gif)
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
sorry only read the top of post #5, hmm so this is a different module then when upgrading to the LED headlight flasher relay.
__________________
Orange County, CA
Orange County, CA
