2014 f-sport rims on isf do they fit?
Id like to know too. I saw a dude in traffic with an IS350C that had nicer looking Lexus wheels than mine. The offset was MUCH better. Not sure if its the offset was better or is it that the body of the ISF bulges out further
Tech Info Resource
strictly by the numbers they look like they should fit, but they're pretty narrow, especially in the rear unless you plan to run slicks.
The answer is in both of these threads:
https://www.clublexus.com/forums/is-...ls-on-isf.html
https://www.clublexus.com/forums/is-...rt-wheels.html
Short answer, the rear caliper causes interference and you would need to use a spacer.
Lou
Lou
So do the 3IS F-Sport wheels fit on an ISF? And would the clearance be safe enough to use them as a winter set? I know in the past others have used the 2IS F-Sport wheels as winter sets.
grondie
IS F (2008-2014)
02-05-11 06:53 AM
