LSD & differential question....
does our F share/interchangable LSD with other toyota's? supra?
question about torque,with my previous cars like the civic,altezza,mr2.....i've driven them with and without lsd,and the "pull" or butt dyno seems to different from non-lsd,i know the lsd will not increase WHP....but does it increase torque? im wondering if i will feel the same with the F since the HP is way above from other cars....i dont know if i will feel any gains like the other cars
Someone was going through some cross compatiblity stuff, I believe they ruled out the is250 was same/similar to the frs/brz. The ring and pinion on isf might be compatible with the crown:
https://www.clublexus.com/forums/is-...-or-not-3.html
After watching http://www.youtube.com/watch?v=5tYv2...ature=youtu.be I really want to test this out, especially due to the fact I have the diff with a giken in it.. Idk how the soon to be installed nitrous setup will be utilized when you are shifting that much. Importfaceoff may 31st, if like to take a trophy home this might be the ticket!
Former Sponsor
-Matt M.
///MDex
03-06-02 09:22 AM
