discovered Lil leakage
Old 04-10-15, 06:19 AM
Gearbangin
Gearbangin's Avatar
Default discovered Lil leakage
So checked water pump and saw a little red crust around it but haven't been losing coolant. I did notice over a year ago level was low so topped off with red and it's been steady. I bet I put 15k on that since then and no loss.
How urgent is it to get the pump replaced?
Old 04-10-15, 01:03 PM
PiusGS
PiusGS's Avatar
I would do a water pump replacement at 10 year or 100k miles.... but thats just me. How many miles do you have?
Old 04-10-15, 01:31 PM
Gearbangin
Gearbangin's Avatar
almost 90 g
Old 04-10-15, 02:25 PM
imp0rted1
imp0rted1's Avatar
i just turned 65k and noticed the pink slime. consumption was minimal but i replaced almost immediately. i would be curious also to know if failure is catastrophic
Old 04-10-15, 03:27 PM
Gearbangin
Gearbangin's Avatar
I guess it could over heat if you didn't stop if it completely failed or ran it dry etc.
Old 04-10-15, 06:30 PM
DansonISF
DansonISF's Avatar
How much is cost to fix it? Or anyone has done this DIY any before I just found out that I am having coolant leak too but i dunno which one need to replace any tips would help Ty
Old 04-11-15, 08:08 AM
imp0rted1
imp0rted1's Avatar
danson this is the thread i referenced. 9aristo attached 2 pdf files on there that walk you through the major steps.
https://www.clublexus.com/forums/is-...p-leaking.html
also this thread for belt removal and routing:
https://www.clublexus.com/forums/is-...-belt-diy.html
basically:
remove engine splash guard
drain coolant from petcock
remove intake elbow
remove coolant reservoir
remove accessory belt
remove water pump
then the reverse for install
one tip i would mention is that the is-f doesn't use a radiator cap on the radiator itself so the way to fill it is through the coolant reservoir
in all it took me about 2.5 hours to do. not too bad just take your time and make sure you follow the torque spec when installing the pump bolts back on.
i think at the dealer its about $600.
I ordered the part from lexus for $160 and 2 bottles of coolant. so in all it was just over $200
916gs400
IS F (2008-2014)
07-28-15 12:13 AM
Gigggdy
02-02-14 12:28 PM
Colpup ES3
10-12-07 02:21 PM
JspecSC3
Performance & Maintenance
05-27-07 07:49 PM
gn3
13
01-25-07 07:48 AM
Quick Reply: discovered Lil leakage
