Wheel Alignment
Wheel Alignment
I just had my wheel alignment done after changing to Michelin Sport A/S 3 + BC Racing (+Swift) Coilover.
The person who did the alignment said the camber can not be adjusted. It's worth upgrade to FIGS front lower arm rear mount and do another alignment. Attached is the alignment.
-2 degrees of camber should not affect tire wear if that is what you are worried about. It's the Toe that will get you...and your setting look fine to me.
The A/S 3 is excellent.. When I had the PSS with almost no thread.. I had about 5 out 10 confident in the car.. The grip on the PSS was not great and on hard turn the car traction sux.
Now with the A/S 3, it is 7-7.5. I have done some spirited driving on the road.. never lost grip nor felt the car was unpredictable... ride comfort is better.. Hope thread life is better.. Only got 17K miles on the PSS.
The alignment looks OK, but you might need to tweak the toe. I run mine at 0.04 on both sides now, and it's working perfectly.
