I saw these LED fog lights have DRL function and I'm wondering if anyone has already done it or if the DRL in the F can be rewire into the fog lights but still obtain the high beam functions in the head light. here is a picture of the LED fog light. DRL on the left and fog light on the right.
I think you should be able to do it by using the right wires from the headlights depending if you have the 2008-2010 lights, upgraded lights, or stock 2011+ lights, but to get it to switch between DRL and normal fog light mode you might need to add a relay.
It looks interesting, but I'm not sure if it would be worth all of the trouble.
Its possible, I think my LED fogs are the same ones and have the option to wire it as DRL LED but M4ksup said something like that it its not bright enough to be noticed in the day time so no point of doing it.
