First Drive Figs-Penske Coilovers
#31
I have the ELSD. The car is still great on track, the main difference is that it's not as effective at putting down the power getting out of the corner. I didn't cook my rear brakes at all in sport, but I am sure I wasn't pushing as hard as Lance normally does. I find it is hard to tell that it's working other than the shimmy. Certainly doesn't feel the same as a car with a true mechanical diff.
I need to test out new parts too. I've changed the suspension up since I was last out.
#32
#33
#34
Toe links and front bushings went in yesterday. Had a slight hiccup with the mega arms but that is getting resolved shortly. Wow, what a difference the bushings make. The steering feels more responsive and under regular, medium, and most importantly threshold braking, there is 0, ZERO, steering wheel float/jiggle/shake. My factory bushings looked to be in perfect condition and the difference between the two is still night and day. The car feels significantly more stable coming down from high speed. Another highly recommended figs offering!!
#40
Originally Posted by darbs242
heading to Thompson speedway to get some track use out of these. First time up with them, Im going to up the stiffness just a bit and see how it goes. Im expecting to be impressed just after street use.
#41
They were great, I went from my daily driving set up which is -35 rebound and -12 compression to -5 rebound and -5 compression, car goes from being stand-able on the street to incredibly stiff and firm. Im sure it does but it doesnt feel like it sways much at all, boosts driving confidence at the limits of the isf 100%. Makes the car feel much lighter. I have never run at the track i was on or with these shocks but i think my lap times were seconds faster than they would have been on the stock suspension or my BC (which i now feel like were not worth a dollar)... Il be at poconos north track this coming Wednesday and will do an in depth review of my own on the shocks then. They really are great track shocks, the daily is rough even when they are set very very soft. I would like to try the KW3 and Ohlins to see if they keep up on the track with higher quality street ride.
I also smoked another set of XP12 carbotechs up front and just ordered XP20 for the next event. im getting 8-10 hours of track use out of fronts with xp12 and although they are good I feel there is better to be had. Carbotech rep told me i will go through rotors faster but the pads will hold up better and my braking zone is going to get shorter... we will see.
#42
FWIW we have been pretty happy with XP8 compound and our 2P rotors. No fade issues and very favorable wear.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
#43
I played with the setting a lot to find a soft daily drive i liked but did shoot in the dark for track settings. I do think i over dampened the compression and will try something more in the middle on Wednesday. Its not that im unhappy with the carbotech xp12. I just want to be able to stop even harder. I havent had any break fade issues either. Maybe your two piece rotors hold up much better than the OEM. For the price il keep buying oem at 275 a set vs the cost of two piece, I have a hard time believing they will out last 3 or 4 sets of factory disks. If you have found some track setting you would like to pass along id listen intently.
#44
I will say we have not had to go past 10 clicks off stiff with the rcomps so I would estimate you should only have to be around 13 off on compression front. stay in the middle in back unless you get rubbing.
Mike
__________________
