Anyone have experience with the RR Racing Air/Oil Separator
#181
Thank you Lou for bringing the slight packing problem to our attention. You got me worried, and I surveyed several customers - no one else seemed to have a problem with USPS boxes/shipping. However, we will start taping the edges of the boxes as well to hopefully avoid your experience.
-- Simon
-- Simon
Didn't see this. My box was sorta ripped up. I just didn't complain bc it was all there. My mailman might hate me too. I get packages all the time.
Overral for the price and the quality. You guys made a great product.
#184
Sponsor
Sorry for the confusion,
Simon
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
#188
My question to those running an AOS. Did you actually have oil consumption problems during track events, during hard driving, and/or during normal driving? It's been my experience that AOS have an amazing way of accumulating a lot of oil, but without the AOS, most cars tend to consume nothing or very little (ie 100-300ml over 4K to 6K miles). So the question becomes, do most AOS present a "problem" that's not really there?
Is the black smoke ugly when it occurs? Yeah, I think so, but is it really a "problem". Based on the shape and design of the ISF/RCF intake manifold, a liquid stream of oil isn't getting into the runners unless you've submerged your car in a vat of oil. I also have a very hard time believing that there are ounces of oil vapor being consumed during track events. That level of consumption would be very apparent with a simple oil level check. I haven't seen much on this site stating that these motors consume oil. The engine would also run absolutely terrible, feel down on power, and perhaps knock/ping.
#189
Sponsor
If you do not track your car, or do not drive it really hard, you don't need an AOS, or anything else for that matter. So based on the way you are driving, if you are only seeing 100ml consumption in 6000 miles... you are not pushing the car at all.
That said, the AOS is not just about reducing oil consumption, that's only part of the equation.
The PCV system catches all the vapors from the crankcase. These vapors are not just pure oil. Your oil has lots of contamination in it, including water, solvents, and fuel. These substances are the first to vaporize when your oil gets hot because they are more volatile than oil. When these substances vaporize, they carry with them some oil.
If you track your ISF and fill up the AOS, you will notice that the AOS contents are very dark and black, even if you have just changed your engine oil just prior to the track day -- this is due to the high content of contaminants in the accumulated oil.
So I am sure you have seen our photos, and photos our customers have posted of the accumulated oil. That same quantity of oil would have passed straight into the intake manifold without the AOS in between -- there is no other explanation. The AOS is not actively sucking oil out of the crankcase, or doing anything to add to the volume of vapors coming from the PCV system.
Lastly, you are talking about a "liquid stream" getting into the intake runners.... but the oil exiting the crankcase through the PCV is a vapor, not a liquid. This vapor condenses in the AOS and becomes a liquid. Without the AOS, it would never condense, but enter the intake runners as a vapor.
Rafi
__________________
#190
That vapor also causes detonation and makes the ECU retard the timing , creating less HP. My car feel great on and off the track with the AOS. . Consistent in the heat and freer from deposits that age the engine
#191
Again though, did you have oil consumption issues prior to the AOS? If the car was consuming ounces of oil during hard driving, then it's consuming oil thus would be measurable on a dipstick. If the car wasn't consuming oil prior to the AOS install, but then showed oil in the AOS catch can after install, then one would deduce that the AOS is capturing oil that's not actually entering the motor. That's what I'm getting at. I've seen very similar instances with WRXs, Nissan VQ motors, and LSX motors.
#192
Never had black smoke and never checked my oil level at the track. I usually get the oil changed right before I go. I added this to my F based on the principle of how it works, the AZ heat, and the AZ heat on the track. Dont regret a thing
#194
Any potential "flaws" by running this in the cold Canadian weather? lol
I recently installed:
FIGS LCA, F-sport rear Sway bar, and KW V3 coilovers
Now that the temperature has dropped I am started to hear squeaking - cannot determine from what yet!
Squeak free for 3-4 months until last two weeks
I bought the version 2, it has still been sitting in the box - have not had a chance to install it yet...
#195
