Anyone have experience with the RR Racing Air/Oil Separator
#196
Sponsor
![](https://www.clublexus.com/forums/images/ranks/rank-vendor2.gif)
Any potential "flaws" by running this in the cold Canadian weather? lol
I recently installed:
FIGS LCA, F-sport rear Sway bar, and KW V3 coilovers
Now that the temperature has dropped I am started to hear squeaking - cannot determine from what yet!
Squeak free for 3-4 months until last two weeks![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I bought the version 2, it has still been sitting in the box - have not had a chance to install it yet...
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
#197
So I am hoping you guys can add your thoughts. I am not a track driver and I dont think I run the car that hard....use it as my daily driver and live in CA.
Within the past few months I have been getting smoke (looks like oil) on the start up every once and awhile. Took it to Lexus and they said nothing was wrong. Took it again and they couldnt get it to replicate the problem. Then recently moved to CA and took it to one of the tuner shops recommended in the forms they said it was a small amount of oil in the intake so they replaced my PCV. They said if that didnt fix the problem it would have to be a catch can solution. Thus bringing me to my question. Does this solution seem like its something that will solve my problem? Does my problem seem right?
Any help is greatly appreciated.
#198
I would say YES. Surprised to see the smoke on start up. Usually that only happens with extreme use and temps . Im sure Rafi will chime in here soon
#199
Thanks for the response. I ordered the part and look forward to seeing if this fixes it. Just thought it was odd as I couldn't find anyone talking about the problem unless they were track guys.
Look forward to see what others think as well.
#200
From what I have learned through a little research and from Rafi I think it will address the issue. The price is right AND it will help maintain the cleanliness of the engine
#201
I added a homebrew separator to my PCV system to test it on a recent track day. I took one of those ebay units that you can take the top off and modified it with SS wool and a dip leg to help in separation. After 3 sessions (1.5 hours) the catch can was half full; assuming about 350ml. once half full and after emptying the can I got a big puff of blue smoke out of the car when I started it. Maybe I need to work on the baffling a bit.
I had to empty it 3 times in the course of the weekend and add a quart of oil. The can caught more than 1 quart over the course of the weekend, so the balance was definitely fuel. See attached picture.
One question/concern I have, is if the catch can actually encourages more oil to be drawn from the pcv by acting as a vacuum storage device? It is hard for me to believe that my intake ingested a quart of oil during my track sessions before I installed this separator.
#202
I think this would be a good time for Rafi (RR Racing) to jump in and answer some of the technical questions for you
#203
Sponsor
As far as non-track benefits from the AOS, we see quite a variability with how guys drive on the street. We have local customer who does not track his car ever, but in the summer months sees a lot of oil accumulation. Guys who don't push their cars see only a few tablespoons accumulate per month.... so it varies.
As far as day to day driving, there is no question the AOS keeps the intake manifold clean. I have popped the TB open on several occasions, and the intake manifold is totally dry.
Rafi
__________________
#204
Thanks for the heads up. I decided to go with the purchase and did the install. We will just have to put it to the test. Seems like a great quality part and was easy to install so thank you.
Rafi
Rafi
#205
So I don't track my car. I drive it fairly easy with a daily wot (or two)when merging, or close to wot. My main reason for getting this would be for long term reliability as I plan on literally keeping this car until it's done. It is mostly my daily driver but it's an 08 and I have 41000 miles.
So is this worth it for my needs? Obviously, I'm asking for and value your opinions. I'm actually a long time member but couldn't login under my old name.
Also, in the pic the guy took with the intake sitting next to the separator is the little breather filter in the middle of the hoses for the intake? Is that because that type of intake does away with the rerouting of the air back into the intake that many intakes don't have? I have read a lot and searched but may have missed this. Thanks
#206
#207
#208
I just want to be clear. I am in no way bashing RR Racing, I'm just sharing my experience.
I had the RR Racing AOS on an RCF which was solely street driven. The unit didn't seem to do much to be perfectly honest. In all of the driving that was performed the can was pretty clean without any accumulation of oil vapor or condensation. I could still se traces of vapor in the intake so I came to the conclusion that there could be improvements.
I decided to build a custom system on both the RCF and my friends ISF using a different can that I use in many other applications made by Radium Engineering. I used the dual can setup and used one can for the manifold side when the PCV is open and the other for the intake tube to get suction under load so the crankcase measure negative pressure. These cans are o-ring sealed so there is no risk of vac leaks either.
Major improvement, the results were almost alarming. Within about a month of normal street driving there was significant accumulation in the cans, one of them being half full. I'm not in the business of building a specific kit for these cars to sell to the public, but if anyone is having issues and are technically capable I would recommend doing something similar to what I did.
