Just installed the Ultimate Steering Response System (USRS) from RR-Racing.
Old 06-14-16, 01:05 PM
  #286
One2beH8ed
One2beH8ed's Avatar
Originally Posted by Sameer89
I still need to install mine... sitting in the garage, no time!!
Are you guys getting your car aligned right after installation?
I would do it either way. Anytime you mess with suspension it is most likely going to throw off alignment in some shape or form.
Old 06-14-16, 01:18 PM
  #287
jspecvtec
jspecvtec's Avatar
I agree. My toe was off when I installed mine and went back to align.
Old 06-15-16, 08:35 PM
  #288
ohiois350
ohiois350's Avatar
Originally Posted by Meraki Autoworks
Yes sir.
-Josh
How much shipped?
Old 06-16-16, 07:23 AM
  #289
Sameer89
Sameer89's Avatar
Just installed mine last night.. What a difference! Anyone know what the final torque specs are on all the bolts? I recall the large 22mm bolts needing to be torqued down to 150 ft. lbs. The inner 17mm I torqued down to 100 ft. lbs. and the bracket piece was hand tightened snug...
Thanks!
Old 06-16-16, 09:43 AM
  #290
mikersoft
mikersoft's Avatar
Thanks!
Here you go...
-Mike
Old 06-17-16, 05:39 AM
  #291
TranV
TranV's Avatar
thanks Mike.
Old 06-17-16, 10:16 PM
  #292
Miqueaseli
Miqueaseli's Avatar
Thanks mike this is my next mod .
Old 06-29-16, 01:51 PM
  #293
Bulls23337
Bulls23337's Avatar
How are are these to install by yourself and on jack stands? I might be able to install mine this weekend.
Old 06-29-16, 02:14 PM
  #294
flowrider
flowrider's Avatar
Received 1,906 Likes on 1,343 Posts
^^^^On jack Stands, I guess I can't really can't stay. I did mine on ramps, and it was a total PITA. There just was no darn room to maneuver. If you can get your jack stands high enough maybe it wouldn't be as bad.
Lou
Old 06-29-16, 02:24 PM
  #295
Rickna
Rickna's Avatar
Jack stands are the way to go. Should take you less than 1 hr.
Old 06-30-16, 06:44 AM
  #296
Evil Teo
Evil Teo's Avatar
you will need room as Lou suggested, it might be hard to remove the old ones out
Old 06-30-16, 08:38 AM
  #297
Greatest
Greatest's Avatar
Mine have been on for about two months. I notice a very slightly rougher ride as others have described. All in all they're great. I mainly got them to improve tire wear. Everything else is a welcome bonus.
Old 07-04-16, 12:57 PM
  #298
Bulls23337
Bulls23337's Avatar
Lou
I have ramps too, but I heard removing the wheels will make it easier so I plan on using jack stands.
Good to hear, thanks!
Did you have to use a pry bar or wrecking bar to get the old ones out?
Old 07-04-16, 01:23 PM
  #299
Rickna
Rickna's Avatar
Yup I used a pry bar.
Old 07-05-16, 07:43 PM
  #300
empathy
empathy's Avatar
its possible without a pry bar. i used my 1/2" wrench and my jack instead of the pry bar. works great cause the jack holds it in place and gives you 2 free hands to do whatever you need. i also did it on jack stands.
i'd advise completely removing the plastic paneling on the bottom. it feels like a bunch of fiberglass shards stabbing you. kinda annoying.
Quick Reply: Just installed the Ultimate Steering Response System (USRS) from RR-Racing.
