Nitrous gurus !Went to the track , dissapointed!
Old 09-08-15, 06:19 PM
KOKISF
KOKISF's Avatar
Go for it. Many have tried, none have succeeded without direct assistance from Lexus. If you are successful, you will have a complete monopoly.
In regards the video of the gtr i think the isf from the roll is
Much faster than the hole shot , that does not mean that isf can dial 134 traps !!!
The isf that did 132 mph was on street tires , direct nos shot i belive 175 and one of the best prepped track in the world .
My two cents
Old 09-10-15, 09:49 AM
ihiryu
ihiryu's Avatar
I would definitely figure out how to configure the maximizer.
Personally, I would probably do 25% at 3000 RPM's, and have it ramp to 100% at about 4700 or so. That way you'll have a little more low end grunt, and about 4700 you shouldn't have any wheel spin whatsoever. The only issue I can foresee is that you'll still be spraying while the car is shifting gears.
Not really a huge ordeal, but you lose quite a bit of nitrous while spraying and shifting.
Old 09-10-15, 09:56 AM
Bakewalk
Bakewalk's Avatar
I run a 40% shot right from WOT, and ramp to 100% in 3.5 seconds, spraying the whole track (progressive controller). This is on Nitto NT05's. I pull much harder off the line and trap around 121mph. But I am very high altitude, my DA time was 11.23 with a trap speed of 124.5... My 60ft was 1.803, but again my DA kills that time, would be lower for sure...
Old 09-10-15, 07:39 PM
KOKISF
KOKISF's Avatar
Did you fix the issue?
Old 09-11-15, 08:44 AM
Bakewalk
Bakewalk's Avatar
Yes, car is running perfect again. No misfires or clunking noises. I updated those threads if you wish to refer to them.
Jz39
IS F (2008-2014)
10-29-16 12:28 PM
idoke1
IS F (2008-2014)
14
04-30-15 08:19 PM
RobPR
IS F (2008-2014)
07-17-12 06:31 AM
Rider
IS F (2008-2014)
17
11-29-11 06:00 AM
KC95SC400
Drag Strip
50
12-01-09 10:55 PM
Quick Reply: Nitrous gurus !Went to the track , dissapointed!
