Starter? Car fails to start
#106
One click just hit me today. 2008 with 113k. Looks like a new starter is in my future.
I see LoBux managed to do his on jackstands, makes me hopeful I won't need a lift to tackle this job
@lobuxracer any tips on doing this using jackstands?
lobuxracer (12-07-23)
#109
Well @calteg misery loves company. My starter just died the day after yours. I had a dead battery, jumping it didn't revive it. So swapped to a new battery and got a single click. My shop (who are the only ones I trust) is busy until mid January. So it's going to be awhile. I'm going to replace the starter, alternator (why not, plus I am going through batteries like crazy), motor mounts (with RR ones), and apparently the starter wire cover per this thread. Good luck on yours!
#110
Tech Info Resource
You'll need the wire cover - 82821-30730 - AND the connector body - 90980-11400 Housing Connector F. The connector attaches to the solenoid and will disintegrate when you remove it. Not a big deal, you just take the wire with the end and stuff it in the new connector body and you're good to go.
lexicon72 (12-15-23)
#111
Tech Info Resource
#112
This was similar to my situation. I replaced a working lead acid battery with the Antigravity battery, and the starter solenoid failed on install. Pretty annoying. I also figured out the relay test and despite repeated attempts to get the solenoid to make contact, it never did.
A few thoughts, while the install is still fresh:
-It's a pretty straightforward job, really only requiring patience. Most complex tools are a lot of varying extensions and a wobble socket. Impact gun helps tremendously too.
-At 113k, my OE headers are in great shape, surprisingly
-For me, the magic combo to support the engine was cinder block + scissor jack with a hockey puck on top. Tried to move the engine as little as possible when I dropped the subframe and this combo seemed to suspend it perfectly
-It's 100% possible to leave the upstream 02 sensors in the headers and pull the entire thing as a unit. Great time saver if you're swapping to aftermarket headers with fresh 02 sensors
-If you're doing a starter replacement, you WILL need to remove the dipstick tube, so just get that out of the way.
-To get to the PITA header nut on the passenger side: Standard 3/8" ratchet with a 12mm deep socket. Oriented it so that the handle is facing towards the hood. Slid a cheater pipe down from the top and broke it loose that way, easy peasy.
inovashn (12-13-23)
