Heater is blowing cold air
Hey everyone
Winter is coming and I am running into a problem, I tried to set my heat at the highest level today and was getting nothing but cold air. I get ice cold A/C, but no heat at any temperature. Would anyone have any insight to what could be the culprit?
Thank you for the response! I noticed today, when I am driving (especially when I drive hard) the heat begins to work, but at a standstill it goes cold again.
I will check the coolant level once I get home.
Vinnisf (01-04-22)
The water pump was replaced by the previous owner, and the radiator was replaced under warranty as well. I am thinking it may hopefully be an issue with it just being low on coolant. I will check later on today and report.
I had mt recall work and the car still loses coolants ever so slightly. It's annoying but I am hoping they will find the coolant leak into the valley plate when they do the fuel system recall . I just keep adding a couple of ounces of distilled water every 2-3 months. I will probably order some coolant since this seems like its will be a minor , although chronic issue with the ISF
Thanks everyone! I checked today and the coolant was on the low side... I filled it up with some Toyota coolant and drove around and now the heater is finally hot! Thanks again
Vinnisf (01-04-22)
Tech Info Resource
More importantly, you need to find the leak. It might be in the valley of the engine, and if it is, it's a PITA to fix.
shinbo
03-03-19 01:34 PM
thomashmc1
12-18-17 07:29 PM
