Thinking about Adams rotors
So my rotors need replacing in the next couple thousand miles and I'm going to give adams rotors a try. My question is which pattern do I go for? I'm trying to decide between the slotted, double slotted, and double slotted & dimpled rotors. I'm looking for a set of rotors that will last longer than the OEM ones and have the same stopping power, if not better. Also I do wan't to go to the track sometime (but i'm not sure when). My first choice is the AR Track double slotted and dimpled rotors, but what do you guys think? I'm no brake guru so any insight is much appreciated
Thanks in advance
Thanks in advance
I had the dimpled on my X5M they looked awesome but made a swooshing noise you could hear when driving with your windows down.... Aside from that no complaints.
They also took about 3x as long as Adam said they would and they weren't finished like I wanted. Overall his service was poor but I think they had to buy stock X5M rotors and dimple them because his supplier couldn't make them so maybe it was an isolated incident
I have Adams Rotors on the front of my F. My experiences are outlined below:
https://www.clublexus.com/forums/is-...nt-rotors.html
https://www.clublexus.com/forums/is-...-brakes-2.html
I still have them on my car, and with my Ferodo DS2500 Pads (obtained from Forum vendor SpeedFreaksUSA) they provide very powerful performance. They are still true and are wearing very well.
However, because of my past experiences with the flaking paint on the hats, the substandard packaging they were shipped with and the, IMHO, extremely poor customer service from the vender I cannot recommend them.
If you do decide to go with them, I recommend against paying extra for the painting of the hats.
Lou
Lou
I have the double slotted rotors and I think it is quite aggressive and aesthetically pleasing. While Adams screwed up my order also, they rectified that by sending me the right ones. They had sent me the wrong pattern.
I have had them on for a year. They haven't warped or anything like that at all. Still true. Only thing I noticed with my current brake set up, everytime I wash my wheels, it leaves a coating on my rotors. Not sure if it's the pads or the rotors themselves but they leave a hard coating and it's a pain to get off. You really have to get on the brakes hard a good few times to clear them off. If you don't, it feels like the rotor is just warped.
I use stoptech pads with the Adams rotors. Do any of you have this issue after washing your wheels with the stoptech pads?
I don't like the stock rotors because they are drilled, and IMO, those holes can crack or become filled with junk. A much better choice is a slotted design. There has to be a reason Lexus abandoned drilled rotors on the RCF in favor of slotted. As I said I'm pleased with my Adams slotted rotors now that I've had them for awhile, but I will never buy from them again.
An alternative might be these:
http://speedfreaksusa.com/i-11676395...plxdf9309.html
I know they are expensive, but CL members do get a discount.
Lou
Lou
Well appearance is on my list but my main priority is to have some that perform the same or better than the OEM rotors. I do want to go to the track every now and then so I need a pattern that will that is well suited for track and street use.
If your not road racing the stock rotors will do everything you need them to do. If your going to spend money on performance pads and rotors then save and buy a higher quality part. I personally like the slotted rotors as you don't lose as much contact area with the pad. If I was the slightest bit concerned about brake cooling you can be sure I wouldn't expect a slotted or drilled rotor to do the job alone, there would be some brake cooling ducts and hose installed for sure.
The OEM rotors are very capable at the track, the only problem is they have the same problem all drilled/holed rotors have - they crack sooner than blanks or slotted rotors. On a track where brakes are heavily taxed they will crack beyond limits in a few weekends. Other tracks, not so much, but still will not outlast blanks or slotted rotors.
Rotor performance is really about longevity. While there are some differences in alloys, they are all cast iron, and the only real differences are how they are vented. The surface friction differences can be solved with pad selection, so the real question is, how long do you want them to last under severe use? You will be hard pressed to beat the OEM rotors without spending a lot more money up front.
