Winter Tire Question | Performance All Season vs Performance Winter
So for the upcoming Winter season I'm considering purchasing a set of winter tires. I've done a lot of reading both on here and TireRack and one of the posts here mentioned a good consideration factor is what the actual snow and overall weather conditions are in your area. Obviously for heavy snow conditions a true Winter tire, possibly studded, are what you should consider whereas light/moderate snow conditions may only warrant a performance all season tire. I live in MD and the amount of snow we see can vary from little-to-none to 5-7 inches (which understandably may still be little for some) so I'm kind of on the fence as to which would be a better fit.
With all that said I'm trying to decide between two tires; Bridgestone's Blizzak LM-32 and Michelin's Pilot Sport A/S 3. The Bridgestone's are labeled as a Performance Winter tire and naturally have great ratings for snow and ice while still having considerably good ratings for other important areas like comfort, treadwear and even dry traction. The Michelin's on the other hand have "good" ratings for snow and ice handling and the other key areas are to be expected for both a Michelin and tire in the All Season category. Price wise they're pretty comparable with the Bridgestone's coming in at about $1090 for a set of 4 in OEM sizes and the Michelin's coming in at about $960.
I guess what I'm asking is for any thoughts, suggestions or recommendations my fellow F-drivers might have when considering a Winter tire selection for our cars (OEM sizes) in a an area where the amount of snow to be expected is pretty much 'unknown' but can expect things like sleet/freezing rain and even just rain mixed with cold temperatures to be a given. Last year we saw temps in the teens and low 20's for several weeks and my concern with the compound of an all season tire in those cold/freezing conditions is that they won't perform as hoped or expected. On the flip-side, is going with a "Winter tire" going to be overkill and potentially provide an undesirable ride (from a general comfort and road noise perspective)? Thanks in advance.
All seasons generally don't perform well in winter conditions. They're basically more of a dry and wet tire. If you're looking for a serious all rounder I'd look at an "All-Weather" tire. Nokian makes a few and have heard only good things.
That being said I live on the west coast and have very mild winters. I used to run winter tires on my is350 but found they were overkill. By mild I mean temperatures at or around freezing and usually no snow. This time round I've actually gone with the Michelin a/s 3's you mentioned. We'll have to wait and see how they perform on the F.
Well, I think that if you're purchasing a second set of tires anyway go for real winter tires, over here in Quebec winter are mandatory from Dec 15 and there is really a difference between all season and winter, as for studded tires it's really noisy and I wouldn't put that on any of my cars, my advice would be buy any real brand directional winters and your good to go, nokian hakkapellita being the best, a little narrower digs better in snow.
Thanks everyone!
I live in the same area (NoVA). If you're going to use a dedicated set for the winter season, I'd recommend a performance winter tire (like the Blizzak). I used to run Blizzak (LM-25, I think) on my IS350.
During the "Carmageddon" snowstorm of January 26, 2011, I was one of the unfortunates that left the office too late in the day and the got caught up in the gridlock with heavy snow falling at a rate of an inch or more per hour. It took me over 7 hours to get 28 miles, but the Blizzaks were able to keep me going.. The snow was so deep as I got close to my house that I almost didn't make it.. I was running red lights to keep my momentum![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
I never want to have my IS F in a situation like that. Last winter, I kept the summer tires on, but left my office early or simply worked from home when there was any chance of snow. I bought an old 4x4 pick-up for this year, so I'll just leave the F in the garage whenever the roads are nasty.
-Mike
-Mike
I have done it both ways and highly recommend winter tires. Did Blizzak LM 25s with separate wheels on my IS300 for 12 Ohio winters and they worked great. Now have Michelin A/S 3s on both the IS300 and the ISF starting last winter. They did pretty good but it was a mild winter. Have 15,000 miles and 1 HPDE on them for the ISF and the wet traction has significantly dropped enough where I am worried about this upcoming winter. Go with winter tires like the Blizzaks...you won't regret it. They will feel a little spongy/soft but worth it when it snows.
-Mike
-Mike
I meant to ask that, if you are going to run summer and winter set ups you might as well get winter tires vs all seasons. I run nokian studded tires but like I said we have long cold winters and most people can't believe I even drive an ISF in the winter at all. So you would be fine on a non-studded nokian or Blizzaks are usually the most common. I went square set up with 235mm all around and they seem to do the trick.
This will be my first year with a studded winter tire, but for both of my ISF's I ran blizzaks performance winters (lm25 which are terrible tires, and lm32)
If you've got mostly dry winter roads the blizzaks are hard to beat; if you have substantial snow or slush they don't hook up worth ****
Look into the Nokian WRG3 series. Full on snow tires lag well behind everything else in wet weather, testing shows this.. wet conditions are a huge part of winter driving.
I ran LM-60 last winter (could not afford a new set of LM-32) on my ISF and it performed really well. Granted it was not a lot of snow last winter and I did stayed home on the snow storm days. I plan on going through winter again this year with the same set up. My tire sizes are 225/45/19 and 245/45/19
The year before (2013), I owned an IS250 and I used Bridgestone WS70 and drove through a snow storm. It was not a pleasant experience but the tires gripped really well on deep snow.
Thanks again everyone! These personal experiences and feedback are extremely helpful and exactly what I was hoping to get! A lot of times the feedback you see/read on the manufacturer or TireRack sites are tough to gauge for a number of reasons. I wanted to get personal experiences from those with the same car and who've been through it all so to speak in regards to light and heavy snow storms. Again, extremely helpful so thank you. I think I've settled on going with the Blizzak LM-32's for now. If I remember I'll report back on my experience with them once I've had a chance to put em to use.
