Will 18x8.5 +35 offset fit ISF?
I'm currently running a 18x8.5 +35 square set up, 255/40 tires and camber -2° front -1° rear. No rubbing issues until I put 5 mm spacers on all fours. Fronts were fine, rears rubbed a lil. Rears would most likely clear if I rolled that inner lip in the rear fenders.
So if you want 18x9.5 with 285s in the back, a minimum of +43 offset would probably best.
I've never seen an 18x9.5 +43 though, unless it's built to order.
I have yet to see anyone run a 9.5 et 38 on here. I have questioned if this offset will clear with zero feedback. There is one member running a 40 offset, but he had previously rolled his quarters and so he cannot speak as to fitment. Most squared setup members are running 45 offsets.
