WOT downshift, is yours the same?
I would assume it is but just want to check.
Following videos are in sport mode/automatic.
Above 40mph, wot downshift is fairly quick, just a slight delay.
Below 40mph, it's feels like it hangs up in an intermediate gear before finding 2nd and taking off. Quite a big delay between wide open throttle and the car actually accelerating.
Am I asking too much for it to be nearly instant? Maybe. Just frustrating when the original trans in my 59 Cadillac downshifts faster at 35mph.
My car has had the gas pedal recall done. I'm interested to hear from people who have not had this done, does your car downshift the same?
At 42mph- https://www.youtube.com/watch?v=OpUe...ature=youtu.be
At 37mph- https://www.youtube.com/watch?v=QfMY...ature=youtu.be
Well, I take comfort in knowing that this happens to others as well. I went as far as having my transmission fluid level checked (found to be normal), cleaning the MAF, and trying it a various temps/times. Not a biggie with the choice to go manual, but it is occasionally inconvenient during overtaking or moments when you want that extra second of time in auto.
mine does this as well.
Interesting development... I just put the stock airbox and afe dry drop-in back in the car (removed K&N intake and oiled filter) and the change in shift smoothness is noticeably different. Down-shifts are quicker and smoother in auto-mode and rev matches in manual mode are improved with respect to smoothness too.
During the visit, the tech stated that trans fluid was checked and found to be within limits with nothing added. So there was no intentional adjustment of fluids. After reading about how the sensors (throttle position, MAF value, rpm, steering angle, etc.) affect transmission shift behaviors I guess it is feasible that the flow over the MAF sensor in the stock housing could be less turbulent (or just different) and could make a difference.
I love this car because it is always fun, but it sometimes leaves me shaking my head with some of its fickle tendencies. Haha.
Now that you mention this... i have the same issue, below 40 the car downshifts quick. Anything above it rev matches a little slower with a deeper pitch. Still sounds cool though. Relieved to hear others do this as well, although i've disregarded it, but in the back of my mind kinda wondered.
Tech Info Resource
You got BS'd on the fluid check. There is no such thing as "within limits," there is only some came out or some didn't. If none came out, it is low. If some came out, then it is correct. It sounds like your tech didn't do what he was supposed to do if it is "within limits."
Not surprising. I've experienced the same in prior cars and it's more proof why filters on sticks are a waste of cash and almost always result in worse performance and reduced drivability.
The likely reason why there's a delay at just under 40mph is because you're asking for a downshift in a spot where the engine computer could select one of two gears for ideal acceleration. It evaluates your steering angle, G load, throttle input % requested, tranny fluid temp, etc. among a handful of other variables and considerations. The engine computer is likely trying to make the decision on whether the downshift would cause a loss of control. The end result is a delayed response in automatic mode.
