Buying a 2009 ISF
Old 11-12-15, 09:40 PM
BJM2014
BJM2014's Avatar
Hi, I am in Vancouver and have an 2009 ISF and love it. It can run as a daily driver and then on the track, the ride is a little harsh at times, but it is fantastic. I have checked Mr Lube and private garages and they are not cheaper than going to Lexus for service. Cheers.
Old 11-14-15, 08:51 PM
INTMD8
INTMD8's Avatar
Originally Posted by liquidtek
while stopped long press the traction control button a few seconds
You can turn it off while moving as well. (mine does anyway)
Old 11-14-15, 09:17 PM
Tokenblkgy
Tokenblkgy's Avatar
Originally Posted by alex2192
Hey Token, Not sure what you mean...
I meant wheels, I did this on my phone so I might have fat fingered it Lol.
Old 03-21-16, 09:16 AM
alex2192
alex2192's Avatar
Finally had a nice day to work on my car. As some of you may know i had a decent amount of headlight condensation which led to burnt ballast.
Got a replacement ballast from eBay for 80$.
With Retro Rubber sealant 17$
With a some patience got everything working again.
Old ballast
Once everything was done i figured i still had some time so i painted my calipers.
Did a base coat of silver then blue With Ftype logos.
Lastly installed my Carbon front lip
Old 03-21-16, 09:32 AM
mindcrime
mindcrime's Avatar
Is the ballast inside the headlight? also, what are the steps for painting the calipers; is the paint holding up? they looks good.
Old 03-21-16, 09:43 AM
alex2192
alex2192's Avatar
The ballast is mounted to the bottom of headlight but to remove the wires you need to open the unit. Figure thats why Lexus charges 1800$ for a new unit when the ballast goes.
Painting calipers.
1) Sanded with 400 Grit then 600 Grit
2) Sprayed 2 light layers of VHT Silver Caliper paint
3) Sprayed 3 layers of VHT Blue
4) Applied Ftype logo
5) Sprayed Caliper Clear Coat
Waited about 5 minutes before each coat.
Old 03-30-16, 09:57 AM
alex2192
alex2192's Avatar
Times like this i wish i had a better camera then my iPhone
Old 03-30-16, 11:49 AM
Ilyalexus
Ilyalexus's Avatar
The better color!
Rxzm
12-19-18 01:54 PM
Adziu
IS F (2008-2014)
21
05-11-18 11:33 PM
adplusone
IS F (2008-2014)
09-18-14 06:00 AM
osofine149
IS F (2008-2014)
24
11-30-07 08:44 PM
Quick Reply: Buying a 2009 ISF
