How to mount "F" on grill?
get two flat top bolts, an aluminum plate, epoxy, and nuts. cut out the plate and mount it on the bolts sticking out on the back of the emblem. apply epoxy. you can screw on the nuts on the inside of the grill to secure the emblem on.
check out post #3.
https://www.clublexus.com/forums/bui...1-present.html
check out post #3.
check out post #3.
check out post #3.
I took the badge, shaved the prongs off the back of it...
I used a thick piece of plastic, easier to cut and epoxy than metal (for me)...
Then I cut the plastic in the shape of the badge.. Drilled 2 holes through it, 2 bolts through the holes... With the screws hanging through the plastic I epoxied it to the badge heavily. Instant weld.
Stick the bolts through the grille... Washers and nuts @ the end of your bolts on the backside of the grille and your set!
So bassically same story as the rest, I used plastic from a CD spindle, rather than metal.
Still standing strong, 150+ mph tested lol. I got the Black Pearl F emblem.... Expect the badge to get beat up a little if you daily.
Good luck brother!
Good luck brother!
Good luck brother!
Good luck brother!
dfwjohnd
05-04-14 09:15 PM
chrisCARL0S
IS - 1st Gen (2001-2005)
02-03-06 11:22 PM
