Having recall radiator fan work then told radiator broken
Old 11-20-15, 04:00 PM
mercurymet
mercurymet's Avatar
Default Having recall radiator fan work then told radiator broken
Hello all
Have you heard of our radiators getting brittle at the plastic nipples for hoses? I was having recall work for the radiator fan done by Lexus of Marin. Then I get a call that the nipple broke when the were removing the hoses for recall work. I have never heard of that and was told the radiators are now plastic and get brittle from heat exposure. In the back of my mind I am wondering if they broke it by being careless. The cost was initially 470 then I asked for a better price and was offered 370 for the new radiator.
Thanks
Old 11-20-15, 04:15 PM
Tokenblkgy
Tokenblkgy's Avatar
Originally Posted by mercurymet
Hello all
Thanks
Or how about they replace it for good will, since they broke it and it was the result of the cooling fans.
Raise hell to your service advisor until they fix it for free.
Old 11-20-15, 04:48 PM
liquidtek
liquidtek's Avatar
Uh, I think they should be covering the radiator for free if it was because of the recall.
Limited Service Campaign (LSC) ELE - Certain 2008 - 2012 Model Year IS F Vehicles - Engine Cooling Fans
Status
Remedy Available
Description
The screws which secure the engine cooling fan motors to the fan shroud could become loose over time and interfere with the operation of the cooling fans. If a fan becomes damaged and inoperative, the engine coolant temperature could increase.
Remedy
Authorized Lexus dealers are requested to inspect and replace the screws securing the cooling fan motors. If the cooling fan is damaged or the cooling fan motor is missing screws, cooling fan assembly will be replaced with a new one. These repairs will be performed at NO COST to vehicle owners. This LSC will be available until November 30, 2017, and will only be available at an authorized Lexus Dealer.
edit:
couple links of other people having theirs replaced from the recall.
https://www.clublexus.com/forums/is-...ml#post8861192
https://www.clublexus.com/forums/is-...ml#post8849584
Old 11-20-15, 05:10 PM
mercurymet
mercurymet's Avatar
Thanks Liquid and Token
I spoke to the service manager again and he is filling in paperwork to see if can be covered under the recall work.
I expect them to cover it since the car was fine before I dropped it off. We'll see.
Old 11-20-15, 05:17 PM
Sylvan
Sylvan's Avatar
If they broke it they should repair it, if it's know to become brittle and break obviously it's defective so also on them...
Old 11-20-15, 05:40 PM
mercurymet
mercurymet's Avatar
Thanks,
Just got a call confirming that they will pay for it. So I'm happy now.
Old 11-20-15, 06:13 PM
j3ff
j3ff's Avatar
Couldn't agree more. Just like the wiring harnesses that have been replaced; if it broke while in their hands, that's for them to correct.
Glad you sorted that all out!
Old 11-20-15, 06:58 PM
Tokenblkgy
Tokenblkgy's Avatar
Thanks,
Awesome!! they replaced mine as they did the cooling fan recall.. glad it worked out. Lexus can afford it. Its Lexus not Volvo!!
Token
Old 11-20-15, 08:11 PM
I8ABMR
I8ABMR's Avatar
Sounds odd. They are acting like they are doing you a favor
Old 11-21-15, 12:45 AM
MK4Sup_isF
MK4Sup_isF's Avatar
Radiator of my 2010 found broken during the recall and it was replaced free of charge.
Old 11-21-15, 01:03 AM
kauaian
kauaian's Avatar
I agree with everyone else here. If the tech broke it they should be responsible for replacing it regardless if it's brittle or brandnew, it broke while they were conducting work. All you can do in these instances is hope for an honest responsible individual. If not can file a complaint but it seems this route will come down to honest responsible management, which we have seen here is not always the case.
Glad it all worked out for you.
Old 11-21-15, 10:51 AM
STLblueF
STLblueF's Avatar
This happened to me as well but they replaced it free of charge with no hassle.
Old 11-21-15, 11:57 AM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Exclamation
These IS F fan bolt recalls are costing Lexus a radiator.. (Often)
But when they do the ELF recall they are giving cusotmers a hell of hard time on the harness protector..??
WTF
Someone at Lexus needs to re write their LSB safety protocols...!!
Like so:
  • If it breaks, it's fixed for FREE
Joe Z
JonGS3
02-13-18 11:26 AM
varithms
GX - 1st Gen (2003-2009)
10-26-15 06:05 AM
fredcrn
01-24-15 01:27 PM
2JZSoarer
Performance & Maintenance
13
09-20-07 10:56 AM
suprandsc
08-27-06 11:03 AM
Quick Reply: Having recall radiator fan work then told radiator broken
