N2O Help!
#63
Well, I did have some questions but I got my nitrous setup hooked up. Combo of being stupid, excited and distracted I denied my initial thoughts that I needed to dilute my e25 blend with fresh 93. I was at 1/4 tank and read about RR racing with they're supercharged shop car running into LPFP strain under 1/5th tank due to fuel slosh. Also, reset my pcm so timing maps would default back to lowest and add timing as necessary. Additionally I opted to run my OE heat range and pull them for inspection after a few pulls.
So I did 3 pulls, couldn't get my purge valve working so first hit was dry and i shutdown immediately, 2nd and 3rd ran perfect - no noises, nothing. 4th hit after cool-down period got a mild misfire and then limp mode. I was on a busy highway (60mph speed limit that everyone does 10mph over on.) So I limped it about 2 miles to the next exit.( paranoid after so many people target fixate and slam into disabled cars)
Got it home and was pretty discouraged, next day did a cold compression test. 2 145, 4 145, 6 125, 8 0psi, 1 160, 3 155, 5 160, 7 155.
Cylinder 8 ground straps were melted onto the spark plug.
Scoped cylinder 8 and found what appears to be ringlands sitting on top of the piston.
Engine is getting pulled tomorrow. Just waiting to haul the cherry picker home and get a capable assistant to separate engine and trans, etc.
I'm really torn here, a built engine would run ~$7k from RR. Used engines are 3-6k and would be much-less stressful and a much faster turnaround.
I could also ask a local machine shop to do the work but I'm nervous about people building the engine who have NEVER touched one.
Pulling heads, timing belts/chains, etc, you name it I'm not scared of ( 10yrs in the industry) but I leave engine work to the people who build engines on the daily.
If I was to build the engine, I might as well get the heads P&P, intake, and RCF throttle body but again this drives up the cost significantly.
Anyway, I'll probably start my own thread with progress and findings.
#64
jesus, that sucks to hear man
Sounds like you got detonation from running too lean?
I guess our fuel system cant handle the demands of nitrous if running ethanol?
Would think E would be more detonation resistant than 93 but must have really been starved for fuel
What size shot were you running?
#65
Please start your own thread .I out together my kit by myself and it has been running fine. What size shot did you run? I have a feeling that you didn't use the correct jets for ethanol and maybe it did starve if you were that low on fuel.
#66
E25 leans us out too much and yeah I thought it would be relatively safe but, all the n2o guys i talked to said NO for e85 It was just a stupid rushed mistake i made and totally forgot to pump before we took the car out.
Tempted to just go with a used engine since it will be way less headache in the long run and I don't have to be paranoid about that $7k dent in my wallet failing on me. I'm confident RR would do good work, but hesistant to spend that much. Also if I go forged, I want to P&P the heads since it would be the prime time to do so.
#67
#69
I had mine running on 91oct.. I added a bit more fuel by using a jet for a 100shot fuel and 75 shot n20. (cant remember the sizes)
But yea Ethanol is a no go with nitrous since you already need 30% more fuel just for the E85 alone. Add the extra demand for the nitrous and then the fuel system is maxed out.
You also should have been running at LEAST 2 step colder plugs.. Also when spraying, it should be in manual mode without hitting the rev limiter. If you hit the rev limiter, that is almost a guarantee for detonation.
the ECU also has to be stock OR a RR tune specifically for nitrous because the timing needs to be retarded.
#70
#71
#72
I was talking about systems that don't have a window switch, like the ZEX systems. You are correct that one step colder is enough, however most tuners will advise to run 2 steps.
#73
#74
That is news to me lol.. My systems is a few years old and why I did it, I went top of the line for the ZEX set up.. I just checked out their site and you are correct. That programable TPS didnt exist from them when I built my set up.
I have this: http://www.zex.com/zx/v8-efi-wet-nitrous-systemhtml/
James4394
IS - 1st Gen (2001-2005)
01-27-14 09:22 AM
ICONYQ
Performance & Maintenance
01-10-09 12:35 AM
Redical
03-06-08 06:13 AM
