RCF wheels on an ISF
#181
^^^^Don't know about an ISX50, but this forum is for the ISF. As stated in an earlier post, I have RCF wheels on my ISF. 255/35/19 in front and 295/30/19 in back. No spacers, I don't like 'em. The front wheel comes within a whisker of the A Arm but clears it fine. For the rear, my fenders are rolled flat, and I rubbed over over bumps or when folks were riding in the back. I shaved 5mm off the rear wheels, changing the offset to +46mm. Now everything's fine
Lou
Lou
#182
Lou
Lou
#183
Necro bump for my F-all upgrade, Have yet to see these on an ISF.
The following 6 users liked this post by YeShrug:
BS ISF (09-28-20),
Joe Z (09-29-20),
MileHIFcar (10-27-20),
NorrinRadd (09-28-20),
roheel (09-28-20),
and 1 others liked this post.
#184
Lou
Lou
Based off of what I've been reading I don't want to deal with any rubbing in the rear when I'm lowered so going from a 19x9.5 +45 in the rear to a 19x10 +50 I'm hoping will avoid any rubbing issues based on what Lou said above?
Also the front now I have 19x8.5 +35 on a 255/35 and I rub at full lock on turns........doing some thinking based on what I've read that if I stay with the same width 255/35 and increase offset to +45 on a 19x10 I would avoid any rubbing issues up front? Or should I go to +50 on the offset in the front just like the RCF/GSF offset of +51 to avoid any rubbing at that width?
Thoughts
#185
I have no rubbing issues with 19x9.5 +35 with 255 tires and lowered in front. The minor rubbing on full lock is probably the plastic vents, just trim it or use a heat gun to flatten it out of the way a bit. even with 19x10 +45 front i see no issues. my other set i run 18x10 +40s front
#186
You're right that rubbing is on the plastic fender liner. I didn't think about using a heat gun to flatten it out but that's good to know that you don't have any issues on the front which means I should be fine running a 19x9 +40 with the 255/35 lowered 😎
#187
#188
Nice…im still the only ISF on these after all this time 🤞🏾
Rossi (10-30-22)
#189
CAN-Toronto I want your 2014 ISF oem wheels
hahahaf
Wheels and Tires Classifieds
04-07-15 12:54 PM
