You do know you will need some pulling and cutting for that offset to fit.
Those wheels usually are made to clear big brakes, I don't think that will be a problem.
Pulling refers to the fender edge being widened to accommodate the tire of the wheel. Cutting or rolling refers to clearing more space on the inside of the fender edge so that there is no rubbing of the wheel or tire against it on road imperfections. I'm a bit more conservative with the wheel approach, so initially I'm saying they'll but will require a roll and smaller tire, but it is doable. I have seen some IS F's with +20s offset in the front, and most said they needed a roll and/or spacer.
