? on use of a battery tender.
Received 1,063 Likes
Reviving this discussion thread..
My IS F has been sitting since mid March with my current COVID 19 work from home arrangements.
I've been pretty much just been taking unnecessary Fun drives to keep the juices flowing..
My Optima Red Top tells me it's not happy with my WFH duties as its been a bit slow to turn over the starter lately..
What tickle charges are you all using today to keep the battery 100% ??
Thanks
Joe Z
Thanks
Joe Z
Tech Info Resource
I bought a relatively high end charger with an AGM setting. From what I have learned online, AGM needs a different charging profile (geez, don't they ALL seem to have special needs?), and Optima is the original AGM spiral wound battery. I no longer have an Optima in my Supra, I have a conventional AGM, but I will be replacing it with a LiFePo4 like the one I have in my IS F because it's light and spins the engine on start like no battery I've ever had before. It also sits for a couple of weeks with zero issues when I want it to start.
The charger I got is a Schumacher XC-103CA (current equivalent model is SC1393) mostly because it has the AGM setting and I found it open box at my local Lowe's for $49. I couldn't pass that up. I retired my previous charger as it did not have an AGM setting, and my experience was it didn't do a good job of keeping my AGM batteries alive over the long term with long periods (sometimes months) of sitting on a charger.
I totally get not wanting to drop $600 on a LiFePo4 battery, but I could not be happier with mine. It really makes a difference you can experience every time you hit the start button.
@lobuxracer great details...
I was looking at the Battery Tender JR... Seems they have two that may work the 750 or the 800mA
https://www.batterytender.com/Batter...tery-Charger_7
What do you think??
Joe Z
What do you think??
Joe Z
Tech Info Resource
What do you think??
Joe Z
What do you think??
Joe Z
Joe Z (08-09-20)
I have a Costco unit, I think Duracell brand. It’s supposed to self regulate based on battery charge, and supposedly capable of charging multiple battery types.
no matter what button I push, it charges at 100% capacity, 100% of the time.
Id return it, but I destroyed the package and it’s been too long. It’ll go for a dumpster swim eventually.
I got a Bosch Smart Charge Pro a couple years ago and used it for a mostly garaged car with a lead-acid battery while I sorted through a problem with its starter motor and alternator. It charges quickly (evidently up to 7A) and tapers off to trickle charge profile nicely. I like having situational awareness from the LED voltage display. It automatically detects battery operating voltage and chemistry. But I never used it with an AGM, so cannot comment on that capability.
This unit is fairly capable...hoping I will never need another charger/maintainer.
I bought it off Amazon for $85...the usual caveats on price volatility apply.
Autozone currently lists it for $100.
https://www.autozone.com/test-scan-a...ger/719747_0_0
Bosch charger model lineup.
Amazon Prime came through already and did the 5 min install of the 800aM unit..
Seemed like a clean fast install until the eyelet ring broke clean off on the positive side
Could have just been bad luck I guess... I was like why isn't it going into charge mode after reading the LED indicators.. Sure enough the eyelet was broken in the insulator.
New unit is already on the way again from Prime but in the meantime I'm using it with the alligator clamps..
Will need to inspect the new one before wrenching on the terminals again. For the permanent cable install.
Joe Z
Joe Z
My battery was at 11.98 - still starting the F but as I said it's been on the slow side for turnover.
It was somewhere above 80% according to the LED indicator and it went into charge mode.. This morning I tested it was right around 13.08 fully charged and in maintenance mode..
I disconnected the battery tender and put it on another car.
Few hours later I tested the Optima again and it was holding at 12.54
Good to mention I started it last week from what I recall..
Edit: Just did first start of this week and it was like a new battery.. Turned over super quick..!!
Charging system on Tech Service / Nav Screen showed the Voltage reading doing well at 14.0 to 14.2 , only ran it a few mins.
Joe Z
Joe Z
Tech Info Resource
Joe Z
Joe Z
Amazon Prime had the new one here within a couple of days..
Got the eyelets / harness wired up and all is working well.
These eyelet rings do not like to be bent, so I need to get an extra nut on the negative side so I can flip the wire and not bend the ring..
Not driving daily anytime soon so this will keep the Optima ready to go when the time comes..
Joe Z
Joe Z
